Got 2 Posted January 15 Report Share Posted January 15 First time posting here. User name due to having a 2012 and 2020 Miss my 6 banger.😟 Putting a trailer light converter in. Got the wiring from the taillights down to below. Trick: After taking out the one screw, pull the taillight assy. off by a piece of duct tape placed horizontally on the lens with a piece hanging out the back to grip. Simple! Looking to power it from the rear lighter instead of running a line all the way to the engine. Only LED lights so no big draw. I assume I won't have power there if the car starts shutting down non-essential loads due to failing battery. That's OK. Easy to get the rubber hatch seal off. How to get the rear inside panel off is the question. Thanx in advance. Dave 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted January 15 Report Share Posted January 15 I ran mine through the wiring harness going through the spare tire well, through the drivers side panels to the mini fuse panel in the drivers foot well. Pretty easy & used a extend a fuse or add a fuse & wired it to something that only turns on when the power to the car is on, like the radio I believe. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 15 Report Share Posted January 15 The 12v accessory power / "cigarette lighter" might be nearby for power. Quote Link to comment Share on other sites More sharing options...
Haz Posted Friday at 01:02 PM Report Share Posted Friday at 01:02 PM Welcome to the Forum @Got 2! Â From the 2020 Edge Workshop Manual... Â Good luck! Â Loadspace Trim Panel - Removal and Installation - 2020 Edge Workshop Manual.pdf 2 Quote Link to comment Share on other sites More sharing options...
