rdavis006 Posted January 13 Report Share Posted January 13 2016 Ford Edge have camera unavailable message. I replaced the camera no change. Scan with for scan and have DTC C1001 in the APIM. Does any one have a pin out diagram for the connector to camera or had similar issue and what was the fix. Thank you 1 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 13 Report Share Posted January 13 Have you completed the LIN new module calibration? 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted January 13 Report Share Posted January 13 (edited) Welcome to the Forum @rdavis006! Echoing @Wubster100, from the 2016 Workshop Manual's final step of the Rear Camera installation procedure: Follow the instructions on the scan tool to configure the rear view camera. If Rear Only Parking Aid Camera LIN Communication The BCM and the rear parking aid camera communicate via a LIN circuit which is a dedicated single wire communication network. The messages sent from the BCM to the camera are: Camera configuration data Display manual zoom request Guideline on/off request Trailer connection status (if equipped with trailer tow) Steering angle Standby enable/disable request The messages sent from the camera to the BCM are: Camera status Display zoom status Camera part number data Guideline status If Front and Rear Parking Aid Cameras LIN Communication The IPMB communicates with the front and rear cameras via a LIN circuit, which is a dedicated single wire communication network. The messages sent from the IPMB to the front and rear cameras are: Camera view request (front camera only) Camera configuration data Display manual zoom request (rear camera only) Guideline on/off request (rear camera only) Trailer connection status (if equipped with trailer tow) Steering angle (rear camera only) Standby enable/disable request The messages sent from the front and rear camera to the BCM are: Camera status Display zoom status (rear camera only) Camera part number data Guideline status (rear camera only) Per your original request: 2016 Edge Rear Camera partial diagnostic Pinpoint Test, with connector pinout and Battery Junction Box (BJB) fuse location... DTC Charts: APIM Pinpoint Test A (Partial) A9 CHECK FOR VOLTAGE TO THE REAR CAMERA Ignition OFF. Disconnect Rear Parking Aid Camera C4357. Ignition ON. Measure: Positive Lead Measurement / Action Negative Lead C4357 Pin 1 Ground Is the voltage greater than 11 volts? Yes GO to A10 No INSPECT BJB fuse 23 (15A). If the fuse is OK, repair the circuit for an open. If the fuse is not OK, REFER to the Wiring Diagrams manual to identify the possible causes of the short circuit. A10 CHECK FOR GROUND AT THE REAR CAMERA Measure: Positive Lead Measurement / Action Negative Lead C4357 Pin 1 C4357 Pin 5 Is the voltage greater than 11 volts? Yes GO to A12 No For vehicles with an 8 in (203 mm) touchscreen, GO to A11 For vehicles with a 4.2 in (107 mm) centerstack infotainment display, REPAIR the circuit. Good luck! Edited January 13 by Haz 1 1 Quote Link to comment Share on other sites More sharing options...
rdavis006 Posted January 14 Author Report Share Posted January 14 Thanks guys for the reply I did try the LIN Module intialization. The procedures aborts and tell me to run self diagnostics test. Ran self diagnostics on BCM the only in BCM is DTÇ B115E. I have checked the connectors behind trim of lift gate they all look fine. I believe next step is pin test? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 14 Report Share Posted January 14 Do you have the front camera with split view, or just the rear camera only? Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 14 Report Share Posted January 14 Parking Aid PAC DT.pdfThis document contains B115E. Quote Link to comment Share on other sites More sharing options...
rdavis006 Posted January 15 Author Report Share Posted January 15 Wubster, I just have the rear 1 Quote Link to comment Share on other sites More sharing options...
