DavidD Posted 19 hours ago Report Share Posted 19 hours ago Trying to add a radar detector to my rear view mirror, and want to confirm power and ground wires to tap. If anyone can identify which color does what, that would be appreciated. Surprisingly I cannot seem to find anything online with the same wire colors. Thanks in advance. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 19 hours ago Report Share Posted 19 hours ago (edited) Welcome to the forum @DavidD Where did you get that connector from? Are you going to get power from the front camera (IPMA)? Edited 18 hours ago by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 19 hours ago Report Share Posted 19 hours ago People have taken power from the IPMA for stuff like dashcams. Image Processing Module A (IPMA) - Connector C9224 Pin-Circuit Details - 2019 Edge.pdf Image Processing Module A (IPMA) - Connector C9224 Location - 2019 Edge.pdf Image Processing Module A (IPMA) and Cruise Control Module (CCM) - Adaptive Cruise with Stop and Start - Wiring Diagram - 2019 Edge.pdf Image Processing Module A (IPMA) - Grounds - Wiring Diagram - 2019 Edge.pdf Image Processing Module A (IPMA) - Removal and Installation - 2019 Edge Workshop Manual.pdf Image Processing Module A (IPMA) - Module Communications - Wiring Diagram - 2019 Edge.pdf Quote Link to comment Share on other sites More sharing options...
DavidD Posted 18 hours ago Author Report Share Posted 18 hours ago The photo is the connector that is behind the plastic housing. I am connecting this wire tap to power up my radar detector. https://www.amazon.com/dp/B082V1245P?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 I just want to make sure that I put the black wire to the ground, and the red wire to the switched hot. I thought the white was the switched hot, but I'm not 100% which is the ground. I'm reading that it might either be the black/white wire, or the brown. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 18 hours ago Report Share Posted 18 hours ago (edited) The necessary diagrams are attached above as PDF files. Edited 18 hours ago by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
DavidD Posted 18 hours ago Author Report Share Posted 18 hours ago 4 minutes ago, Wubster100 said: The necessary diagrams are attached above as PDF files. Thanks. But from what I can tell, sometime after 2019 they started using a different connector and wiring. I've been able to find similar schematics, like the ones that you posted, however, I can't seem to find anything after 2019, and absolutely nothing from 2022. If you look at the block in my original post, it looks nothing like the block C9224. That's where I'm struggling. The wire configuration is different, so it's possible the controls that each color represents are also different. I appreciate the help, but if you can find anything in a later model year, I'd love to see that. Thanks again. 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted 16 hours ago Report Share Posted 16 hours ago Welcome to the Forum @DavidD! 2022 Edge wiring diagram and connector information attached below as PDF documents... Good luck! AUTO-DIMMING INTERIOR MIRROR - Connector C9012 Pinout - 2022 Edge.pdf AUTO-DIMMING INTERIOR MIRROR & IPMA - Connector Locations - 2022 Edge.pdf IMAGE PROCESSING MODULE A (IPMA) - Connector C9224 Pinout - 2022 Edge.pdf AUTO-DIMMING INTERIOR MIRROR & IPMA - Power Distribution Wiring Diagram - 2022 Edge.pdf 1 Quote Link to comment Share on other sites More sharing options...
DavidD Posted 16 hours ago Author Report Share Posted 16 hours ago Thanks!! I think this should do it! I appreciate the help!! 2 Quote Link to comment Share on other sites More sharing options...
