Wubster100 Posted February 16 Author Report Share Posted February 16 Next steps are to permanently install the IPMB, get shielded wire, and install 4 new cameras. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 16 Author Report Share Posted February 16 @Haz Can you post the connector pin out of the front controls for the 2021-2024 Edge? It is the one that connects to the airbag light indicator, camera button, hazard lights button, max defrost button, volume and tune knob, etc. Also curious to see what module these buttons are connected to. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 16 Author Report Share Posted February 16 Nevermind, the information needed is already posted above. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 20 Author Report Share Posted February 20 @Haz Can you post information from the 2019+ Ford Edge China 3 row / 7 seat? Specifically information about the side mirrors and cameras. Quote Link to comment Share on other sites More sharing options...
Haz Posted February 21 Report Share Posted February 21 Good luck! 360 Camera - Wiring Diagram 2 - 2024 Edge - China.pdf 360 Camera - Wiring Diagram 1 - 2024 Edge - China.pdf Parking Aid - Component Location - Description and Operation - 2024 Edge Workshop Manual - China.pdf Side Parking Aid Camera - Removal and Installation - 2024 Edge Workshop Manual - China.pdf 3 Quote Link to comment Share on other sites More sharing options...
JohnKlassen Posted February 22 Report Share Posted February 22 Want to see how this works 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 22 Author Report Share Posted February 22 11 hours ago, JohnKlassen said: Want to see how this works Latest update on my progress: A new rear camera should be here in a few days. I have installed new IPMB firmware to change the vehicle icon to a Ford Edge. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 22 Author Report Share Posted February 22 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted February 24 Report Share Posted February 24 Did you have to do anything in Forscan, or did this work just by plugging it in? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 24 Author Report Share Posted February 24 (edited) Yes, you will need to use FORScan. There will be a change in the BCM to disable the rear camera LIN circuit, because the front and rear camera LIN circuit will connect to the IPMB instead. And some changes in the APIM. Edited February 24 by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 25 Author Report Share Posted February 25 Ok, so I tried to remove the rear camera today. I removed the 2 inner tail lights / reverse lamps. I also removed 6 bolts on the center trim piece, but I just can’t seem to get the center trim piece to come off. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 1 Author Report Share Posted March 1 Thanks to @Beefnuts video, I was able to install a new rear camera. The solution was to pull extremely hard because of all the plastic clips. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted March 1 Author Report Share Posted March 1 On 1/5/2025 at 12:55 AM, omar302 said: Wish you good luck. Maybe also study the possibility of enabling the rear camera to view 180 degrees like the front camera? The rear 180 degree camera is so useful because you can see way more. The view is amazing! 🤩 1 Quote Link to comment Share on other sites More sharing options...
