Retrofit 360 Camera Into Ford Edge
Hello everyone, I will be attempting to retrofit the 360 camera system similar to the Lincoln MKX/Nautilus. The Edge only has the option for a front 180 camera.
@HazI am requesting the following information:
2021-2024 Edge APIM wiring diagram
2021-2024 Edge IPMB wiring diagram
2021-2024 Edge front + rear camera wiring diagrams (with and without IPMB)
2021-2024 Edge camera button wiring diagram
2016-2020 MKX/Nautilus IPMB connector pinout
2016-2020 MKX/Nautilus camera button wiring diagram
  • Thanks 1
@Wubster100: Relevant information from 2020 Nautilus and 2022-2024 Edge Owner's Manuals, Workshop Manuals, and Wiring Resources, is attached as PDF documents below and in an immediately following post, due to Forum file attachment limitations...
Touchscreen WITH Front Split View Camera - APIM & IPMB Wiring Diagram - 2022-2024 Edge.pdf Rear View Camera - Touchscreen WITHOUT Front Split View Camera - Wiring Diagram - 2022-2024 Edge.pdf APIM Module Communications - Wiring Diagram #1 - 2022-2024 Edge.pdf APIM Module Communications - Wiring Diagram #2 - 2022-2024 Edge.pdf APIM & IPMB Grounds - Wiring Diagram - 2022-2024 Edge.pdf APIM Power Distribution - Wiring Diagram - 2022-2024 Edge.pdf SYNC MODULE (APIM) - Connector C2383A Pinout - 2022-2024 Edge.pdf SYNC MODULE (APIM) - Connector C2383F Pinout - 2022-2024 Edge.pdf IMAGE PROCESSING MODULE B (IPMB) - Connector C3676A Pinout - 2022-2024 Edge.pdf IMAGE PROCESSING MODULE B (IPMB) - Connector C3676B Pinout - 2022-2024 Edge.pdf IMAGE PROCESSING MODULE B (IPMB) Module Communications - Wiring Diagram - 2022-2024 Edge.pdf Rear View Camera - Touchscreen WITH Front Split View Camera - IPMB Wiring Diagram - 2022-2024 Edge.pdf Front Split View Camera - Power Distribution & IPMB Wiring Diagram - 2022-2024 Edge.pdf AUDIO CONTROL PANEL (Front Camera Switch) - Connector C2009 Pinout - 2022-2024 Edge.pdf AUDIO CONTROL PANEL (Front Camera Switch) - APIM & HVAC Wiring Diagram - 2022-2024 Edge.pdf HVAC MODULE - Connector C228B Pinout - 2022-2024 Edge.pdf Parking Aid - Overview - 2022-2024 Edge Workshop Manual.pdf Parking Aid - Component Location - 2022-2024 Edge Workshop Manual.pdf Parking Aid - System Operation and Component Description - 2022-2024 Edge Workshop Manual.pdf Parking Aid - 360 Degree View Camera Alignment - 2022-2024 Edge Workshop Manual.pdf Image Processing Module B (IPMB) - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf 360 Camera - Wiring Diagram #1 - 2020 Nautilus.pdf 360 Camera - Wiring Diagram #2 - 2020 Nautilus.pdf 360 Camera - Wiring Diagram #3 - 2020 Nautilus.pdf 360 Camera - Wiring Diagram #4 - 2020 Nautilus.pdf IMAGE PROCESSING MODULE B (IPMB) - Connector C3676B Pinout - 2020 Nautilus.pdf IMAGE PROCESSING MODULE B (IPMB) - Connector C3676A Pinout - 2020 Nautilus.pdf EXTERIOR MIRROR LH - Connector C517 Pinout - 2020 Nautilus.pdf EXTERIOR MIRROR RH - Connector C615 Pinout - 2020 Nautilus.pdf Parking Aid - Component Location - 2020 Nautilus Workshop Manual.pdf Parking Aid - Overview - 2020 Nautilus Workshop Manual.pdf Parking Aid - System Operation and Component Description - 2020 Nautilus Workshop Manual.pdf Side Parking Aid Camera - Removal and Installation - 2020 Nautilus Workshop Manual.pdf
Edited by Haz
  • Thanks 2
Posted (edited)
I searched around the glove box area, and I was able to find one unused connector. This connector is located underneath the ac blower fan. I am not sure if it is some kind of splice or what it is used for.IMG_3824.thumb.jpeg.1b3501c86b0152ff0fe1f23ec7c90802.jpegIMG_3825.thumb.jpeg.a21ec3ae17a07249cb1ef5a0c8163e13.jpegIMG_3826.thumb.jpeg.e46f6305cb94e361becebf1232000845.jpegIMG_3827.jpeg.78d304a744808aeb0636210a4bfea0c0.jpeg
Edited by Wubster100
If your Edge is not equipped with Automatic Headlamp Leveling...
The mid and high series headlamps may be equipped with automatic headlamp leveling. The headlamp beam height is automatically adjusted according to vehicle load, speed, acceleration and braking. Automatic headlamp leveling is activated when the headlamp switch is in the HEADLAMPS or AUTOLAMPS position.
...then it may be Connector C2129 for the Headlamp Control Module (HCM), which is only installed on vehicles equipped with automatic headlamp leveling...
HeadlampControlModule(HCM)-ConnectorC2129Location-2021Edge.jpg.afca1d8708ed061b2cc44d9e3895ba77.jpg
HeadlampControlModule(HCM)-Illustration-2021EdgeWorkshopManual.thumb.jpg.4b22832496db8b28eac4c659fae38a96.jpg
Good luck!
Headlamp Control Module (HCM) - Connector C2129 Pinout - 2021 Edge.pdf
1 hour ago, Wubster100 said:
What is "413-13B Parking Aid - Vehicles With: Parking Aid Camera" from the 2022-2024 Edge WSM?
It goes over the procedure to align the 360 camera system, but why does it exist if the Edge never had a 360 camera system?
@Haz, Do any Ford Edge workshop manuals or wiring resources mention anything else about a 360 camera system? I do not know of any Ford Edges that came with a 360 camera system.
I was similarly curious, especially given the same document's inclusion in the 2021 Edge Workshop Manual, with the same Procedure Revision Date of October 22, 2024.
It's likely an editorial oversight, since lacking side view cameras, it seems only a historical strip of peripheral front camera images would be available for stitching into a time-lapsed view of what has been on either side of the vehicle, rather than a live view of what presently exists.
Good luck!
  • Haha 1
You are a man after my heart! I've done this sort of stuff for a long time,
a long time ago. But, there were no charts and obtaining parts from different
auto manufacturers to modify to fit the current project.
A real funny one was a Salesman came back and asked if I could install remote
control mirrors on a 1974 Fiat 124 Spider. After a quick thought I said "Yes"
and the sale went through. The mirrors came from an AMC dealership and the
New Car Owner loved them!
I applaud you to the MAX!
The IPMB I have also supports Pro Trailer Backup Assist, but that will be disabled.
The only big difference I see between the Expedition and Nautilus is that the Expedition has a hardwired camera button directly to the IPMB. I don't think that will be a big issue, I will try to get the camera button to work over the network instead.
  • Thanks 1
