enigma-2 Posted Thursday at 10:25 AM Report Share Posted Thursday at 10:25 AM 1 Quote Link to comment Share on other sites More sharing options...
Dudester Posted Thursday at 03:23 PM Report Share Posted Thursday at 03:23 PM Dorman??, not really the first name that comes to mind for performance. 1 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted Thursday at 05:25 PM Report Share Posted Thursday at 05:25 PM What an informative video. They fixed what Ford overlooked, or just didn't care about reliability and longevity. I have the 2024 St does anyone know if this ptu is the same as my vehicle or have they made any changes from this ptu? Quote Link to comment Share on other sites More sharing options...
omar302 Posted Friday at 02:43 AM Report Share Posted Friday at 02:43 AM 9 hours ago, STBEAST said: What an informative video. They fixed what Ford overlooked, or just didn't care about reliability and longevity. I have the 2024 St does anyone know if this ptu is the same as my vehicle or have they made any changes from this ptu? The 2019+ Edge refresh got a different PTU than previous models. 2 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Friday at 04:22 AM Author Report Share Posted Friday at 04:22 AM True enough, but the Dorman model had a built-in heat shield, drain and fill plugs (no advantage for 2019+) and improved seals. Usually don't like Dorman parts, but in this one situation, worth considering. I had mine replaced a couple of years ago under extended warranty. They replaced with an upgraded model. But if this one needs replacing, I'd consider this Dorman model. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Friday at 04:25 AM Author Report Share Posted Friday at 04:25 AM 10 hours ago, STBEAST said: What an informative video. They fixed what Ford overlooked, or just didn't care about reliability and longevity. I have the 2024 St does anyone know if this ptu is the same as my vehicle or have they made any changes from this ptu? The sell on Amazon. Look it up and see if they ref your 2024. Dorman 600-234XD Patented Power Transfer Unit Assembly Compatible with Select Ford/Lincoln/Mercury Models (OE FIX) https://a.co/d/3K0kHZo Quote Link to comment Share on other sites More sharing options...
Haz Posted Friday at 05:04 AM Report Share Posted Friday at 05:04 AM @STBEAST: PTU Description and Operation section for 2.7L EcoBoost, from the 2022-2024 Edge Workshop Manual, attached below as PDF document... Good luck! Power Transfer Unit - Description and Operation - 2.7L EcoBoost - 2022-2024 Edge Workshop Manual.pdf 2 Quote Link to comment Share on other sites More sharing options...
TourGuide Posted Friday at 05:20 PM Report Share Posted Friday at 05:20 PM The Amazon reviews cite several reports of seals being installed backwards on this unit causing leaks upon install. As promising as this unit looks - the current run of product seems to have problems - and in the review chain on Amazon - there is no response from Dorman. This kind of thing would create all sorts of chaos in the shop and for a customer. It also appears that for the 2019 and up - where the design changed - this product is not available. 1 Quote Link to comment Share on other sites More sharing options...
TourGuide Posted Friday at 05:25 PM Report Share Posted Friday at 05:25 PM 13 hours ago, enigma-2 said: True enough, but the Dorman model had a built-in heat shield, drain and fill plugs (no advantage for 2019+) and improved seals. My 2019 does not have a drain plug (Thanks FORD) it has the cooler unit in it. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted Friday at 11:30 PM Author Report Share Posted Friday at 11:30 PM 6 hours ago, TourGuide said: My 2019 does not have a drain plug (Thanks FORD) it has the cooler unit in it. Thought that the PTU drain plug was added starting on the 2015 model year. Definitely there on the 2019. Or was there models that still got the 1st gen PTUs? Quote Link to comment Share on other sites More sharing options...
TourGuide Posted 13 hours ago Report Share Posted 13 hours ago 15 hours ago, enigma-2 said: Thought that the PTU drain plug was added starting on the 2015 model year. Definitely there on the 2019. Or was there models that still got the 1st gen PTUs? I have no knowledge of which generation ptu ended up in my 2019, but it does ENRAGE me that FORD designed this GEAR BOX sans the drain plug to make it as difficult to service as possible. In addition to the heat soak with the position - the straight tiny quantity of lube keeping this thing alive is one of the problems. Ford Engineering: "Hey EVERYBODY! We've got this great idea to build a gear box without a way to change the lubricant. Isn't that a GREAT IDEA?!!" Everybody: Sound of crickets.... Quote Link to comment Share on other sites More sharing options...
Haz Posted 10 hours ago Report Share Posted 10 hours ago @TourGuide: Information on your Edge's PTU from the 2019 Edge Workshop Manual. attached below as PDF documents... Good luck! Power Transfer Unit (PTU) Draining and Filling - 2.0L EcoBoost - General Procedures - 2019 Edge Workshop Manual.pdf Power Transfer Unit (PTU) - 2.0L EcoBoost - Description and Operation - 2019 Edge Workshop Manual.pdf Power Transfer Unit (PTU) - 2.0L EcoBoost - Specifications - 2019 Edge Workshop Manual.pdf Power Transfer Unit (PTU) Fluid Level Check - 2.0L EcoBoost - General Procedures - 2019 Edge Workshop Manual.pdf 2 Quote Link to comment Share on other sites More sharing options...
TourGuide Posted 10 hours ago Report Share Posted 10 hours ago The Haz, the myth, the legend - Thank you again for helping the community Haz! I actually own the ST with the 2.7 and I have the aux cooler strapped on my ptu. Quote Link to comment Share on other sites More sharing options...
Haz Posted 9 hours ago Report Share Posted 9 hours ago @TourGuide: The content of 2.7L EcoBoost PTU documents is identical to the above-posted 2.0L EcoBoost versions. I saw 2.0L Forum posts on your Profile and just assumed -- and we all know what that makes me! Good luck! 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 4 hours ago Report Share Posted 4 hours ago 5 hours ago, TourGuide said: The Haz, the myth, the legend - Thank you again for helping the community Haz! I actually own the ST with the 2.7 and I have the aux cooler strapped on my ptu. Please add your Model and Year to your profile signature, and location - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
1004ron Posted 4 hours ago Report Share Posted 4 hours ago Is there a list of what's upgraded in the PTU shown in the video, or is it only the thermal shield? Quote Link to comment Share on other sites More sharing options...
TourGuide Posted 2 hours ago Report Share Posted 2 hours ago 2 hours ago, 1004ron said: Please add your Model and Year to your profile signature, and location - https://www.fordedgeforum.com/settings/signature/ I actually just went in and checked that - it is in my profile. Maybe I need to add a custom signature or something. Quote Link to comment Share on other sites More sharing options...
TourGuide Posted 1 hour ago Report Share Posted 1 hour ago Couple interesting bits of trivia about this process with the cooler installed on my unit. On my unit there is no drain plug - so - I am stuck with an extract and fill - as a jobber solution (cheaper) that doesn't follow the service procedure. OR According to the OE instructions - I remove and replace the cooler unit with a new one (service kit alone is ~$300 bucks) - then your looking at fluid and labor to remove a frame cross member to even be able to remove the cooler in the first place. I have no idea what the labor on that would be - I'm guessing expensive. All of this in order to do a proper spill and fill - because it doesn't have a drain plug. Quote Link to comment Share on other sites More sharing options...
