dadrett Posted March 24, 2009 Report Share Posted March 24, 2009 (edited) Bits of this are scattered about elsewhere, but here’s some new too. For those wanting to install LEDs in U’r puddle lamps, but are reluctant to try :unsure: because of cost to replace damaged original, here's good news. Least expensive I’ve found is from Tasca Ford in Cranston, RI. (http://www.tascafordparts.com//index.do) Got dealer’s name & part number (3F1Z-13B375-AA) on an F-150 forum. Apparently this is an F-150 number, but I called Tasca & part is same for Edge. Cost $26.13 + $10.00 S&H. Now U can cut one apart :yup: knowing it can be replaced somewhat reasonably. The F-150 poster talked about using razor saw to separate lens from body. I think U have better control than with a rotary tool. I used an Exacto razor saw with .008 in. blade. Put lamp in vise with lens against one jaw. Cushion jaws with tape, close on lamp gingerly & rotate unit as U cut. Sawing with U’r hand on back of blade with saw turned backward & pulling toward U gives better control. (Japanese saws have teeth pointing backwards & cut on the backstroke. If U’ve never used such a saw, try it if U have a chance). Be patient. The cut will be about 1/16” deep & when U think cut is complete, gently worry the two pieces apart by prying with small screwdriver. While prying, if U come to a spot where U don’t see any movement U probably need to cut some more in that area. U won’t be able to cut at big black tab, but if U’r gentle, lens will crack :blink: (yes, I said crack) away from body. A word of caution. The second one goes so much faster (10 mins) than first (50 mins) that U need to check frequently to see if U’r cut is deep enough without going so deep that U cut into lip on clear lens. Reflector removal depends on U’r LED bulb. Bulb (from eBay seller EnKMall) is 8.15 mm x 31 mm. Cost $7.98/pr., free S&H. Even though only 4 LEDs, it's quite good, but hard to tell by pic. I'm guessing quality & intensity of color a little strange due to ambient light. Maybe should try in a very dark parking lot. Edited May 1, 2009 by dadrett Quote Link to comment Share on other sites More sharing options...
BlazedUp Posted March 24, 2009 Report Share Posted March 24, 2009 Lex already did this. Quote Link to comment Share on other sites More sharing options...
dadrett Posted March 24, 2009 Author Report Share Posted March 24, 2009 (edited) BlazedUp said: Lex already did this. True enough & I think we all :party2: should thank Lex & lexington1 for leading the way. As I said, some is old, some new. Lex cited $50-60 each for puddle lamps. My dealer wanted $67.69. Now we know they're available for $36.13 (S&H inc.) ($62.26/pr, S&H inc.) There's a part number for those interested. New thread offers a recognizable name for topic so U don't have to search around. Best of all there are details that may give someone that little nudge :poke: to give it a try. Edited December 28, 2009 by dadrett Quote Link to comment Share on other sites More sharing options...
MJ5150 Posted December 28, 2009 Report Share Posted December 28, 2009 I ordered two from my dealer. It was $54 for both, they gave me a deal. -Mike Quote Link to comment Share on other sites More sharing options...
Hateonhaters Posted March 18, 2011 Report Share Posted March 18, 2011 On 3/24/2009 at 7:33 PM, dadrett said: Bits of this are scattered about elsewhere, but here’s some new too. For those wanting to install LEDs in U’r puddle lamps, but are reluctant to try :unsure: because of cost to replace damaged original, here's good news. Least expensive I’ve found is from Tasca Ford in Cranston, RI. (http://www.tascafordparts.com//index.do) Got dealer’s name & part number (3F1Z-13B375-AA) on an F-150 forum. Apparently this is an F-150 number, but I called Tasca & part is same for Edge. Cost $26.13 + $10.00 S&H. Now U can cut one apart :yup: knowing it can be replaced somewhat reasonably. The F-150 poster talked about using razor saw to separate lens from body. I think U have better control than with a rotary tool. I used an Exacto razor saw with .008 in. blade. Put lamp in vise with lens against one jaw. Cushion jaws with tape, close on lamp gingerly & rotate unit as U cut. Sawing with U’r hand on back of blade with saw turned backward & pulling toward U gives better control. (Japanese saws have teeth pointing backwards & cut on the backstroke. If U’ve never used such a saw, try it if U have a chance). Be patient. The cut will be about 1/16” deep & when U think cut is complete, gently worry the two pieces apart by prying with small screwdriver. While prying, if U come to a spot where U don’t see any movement U probably need to cut some more in that area. U won’t be able to cut at big black tab, but if U’r gentle, lens will crack :blink: (yes, I said crack) away from body. A word of caution. The second one goes so much faster (10 mins) than first (50 mins) that U need to check frequently to see if U’r cut is deep enough without going so deep that U cut into lip on clear lens. Reflector removal depends on U’r LED bulb. Bulb (from eBay seller EnKMall) is 8.15 mm x 31 mm. Cost $7.98/pr., free S&H. Even though only 4 LEDs, it's quite good, but hard to tell by pic. I'm guessing quality & intensity of color a little strange due to ambient light. Maybe should try in a very dark parking lot. What color are those led lights? blue or hyper white? Quote Link to comment Share on other sites More sharing options...
dadrett Posted March 19, 2011 Author Report Share Posted March 19, 2011 On 3/18/2011 at 11:29 PM, Hateonhaters said: What color are those led lights? blue or hyper white? These bulbs are white, but I can't say that they're hyper or super white. Keep in mind I did this two years ago. I went to eBay & searched for LED lights, found that enkmall is still in business but it looks as though his product line has changed. Where ever U buy make sure U get 31 mm length. Quote Link to comment Share on other sites More sharing options...
Hateonhaters Posted March 19, 2011 Report Share Posted March 19, 2011 On 3/19/2011 at 4:14 AM, dadrett said: These bulbs are white, but I can't say that they're hyper or super white. Keep in mind I did this two years ago. I went to eBay & searched for LED lights, found that enkmall is still in business but it looks as though his product line has changed. Where ever U buy make sure U get 31 mm length. Thank You... I just ordered a pair of 31mm off of retro-solution site. Quote Link to comment Share on other sites More sharing options...
Ford Edge 2011 Posted March 31, 2011 Report Share Posted March 31, 2011 On 3/24/2009 at 7:33 PM, dadrett said: Bits of this are scattered about elsewhere, but here’s some new too. For those wanting to install LEDs in U’r puddle lamps, but are reluctant to try :unsure: because of cost to replace damaged original, here's good news. Least expensive I’ve found is from Tasca Ford in Cranston, RI. (http://www.tascafordparts.com//index.do) Got dealer’s name & part number (3F1Z-13B375-AA) on an F-150 forum. Apparently this is an F-150 number, but I called Tasca & part is same for Edge. Cost $26.13 + $10.00 S&H. Now U can cut one apart :yup: knowing it can be replaced somewhat reasonably. The F-150 poster talked about using razor saw to separate lens from body. I think U have better control than with a rotary tool. I used an Exacto razor saw with .008 in. blade. Put lamp in vise with lens against one jaw. Cushion jaws with tape, close on lamp gingerly & rotate unit as U cut. Sawing with U’r hand on back of blade with saw turned backward & pulling toward U gives better control. (Japanese saws have teeth pointing backwards & cut on the backstroke. If U’ve never used such a saw, try it if U have a chance). Be patient. The cut will be about 1/16” deep & when U think cut is complete, gently worry the two pieces apart by prying with small screwdriver. While prying, if U come to a spot where U don’t see any movement U probably need to cut some more in that area. U won’t be able to cut at big black tab, but if U’r gentle, lens will crack :blink: (yes, I said crack) away from body. A word of caution. The second one goes so much faster (10 mins) than first (50 mins) that U need to check frequently to see if U’r cut is deep enough without going so deep that U cut into lip on clear lens. Reflector removal depends on U’r LED bulb. Bulb (from eBay seller EnKMall) is 8.15 mm x 31 mm. Cost $7.98/pr., free S&H. Even though only 4 LEDs, it's quite good, but hard to tell by pic. I'm guessing quality & intensity of color a little strange due to ambient light. Maybe should try in a very dark parking lot. I just ordered my puddle lights - do you have any other suggestions? Quote Link to comment Share on other sites More sharing options...
dadrett Posted March 31, 2011 Author Report Share Posted March 31, 2011 On 3/31/2011 at 1:11 AM, Ford Edge 2011 said: I just ordered my puddle lights - do you have any other suggestions? Just follow the instructions in post #1. Quote Link to comment Share on other sites More sharing options...
Ford Edge 2011 Posted April 16, 2011 Report Share Posted April 16, 2011 On 3/24/2009 at 7:33 PM, dadrett said: Bits of this are scattered about elsewhere, but here’s some new too. For those wanting to install LEDs in U’r puddle lamps, but are reluctant to try :unsure: because of cost to replace damaged original, here's good news. Least expensive I’ve found is from Tasca Ford in Cranston, RI. (http://www.tascafordparts.com//index.do) Got dealer’s name & part number (3F1Z-13B375-AA) on an F-150 forum. Apparently this is an F-150 number, but I called Tasca & part is same for Edge. Cost $26.13 + $10.00 S&H. Now U can cut one apart :yup: knowing it can be replaced somewhat reasonably. The F-150 poster talked about using razor saw to separate lens from body. I think U have better control than with a rotary tool. I used an Exacto razor saw with .008 in. blade. Put lamp in vise with lens against one jaw. Cushion jaws with tape, close on lamp gingerly & rotate unit as U cut. Sawing with U’r hand on back of blade with saw turned backward & pulling toward U gives better control. (Japanese saws have teeth pointing backwards & cut on the backstroke. If U’ve never used such a saw, try it if U have a chance). Be patient. The cut will be about 1/16” deep & when U think cut is complete, gently worry the two pieces apart by prying with small screwdriver. While prying, if U come to a spot where U don’t see any movement U probably need to cut some more in that area. U won’t be able to cut at big black tab, but if U’r gentle, lens will crack :blink: (yes, I said crack) away from body. A word of caution. The second one goes so much faster (10 mins) than first (50 mins) that U need to check frequently to see if U’r cut is deep enough without going so deep that U cut into lip on clear lens. Reflector removal depends on U’r LED bulb. Bulb (from eBay seller EnKMall) is 8.15 mm x 31 mm. Cost $7.98/pr., free S&H. Even though only 4 LEDs, it's quite good, but hard to tell by pic. I'm guessing quality & intensity of color a little strange due to ambient light. Maybe should try in a very dark parking lot. Great post it helped a lot, thanks! Quote Link to comment Share on other sites More sharing options...
Edgieguy Posted April 16, 2011 Report Share Posted April 16, 2011 Very nice. Thanks for taking the time to take pics, and post up a write up for anyone who mightve missed it first time on the older models. Quote Link to comment Share on other sites More sharing options...
dadrett Posted January 5, 2012 Author Report Share Posted January 5, 2012 On 1/4/2012 at 11:38 PM, kc300c said: Does the LED bulb you used have another set of 4 LEDs on the back side? I can't tell by the photo of the bulb installed in the assembly. No, the bulb has only the four LEDs U see. Surprisingly, the light output is quite good. It seems that enkmall (eBay) still sells these @ $6.38/pr. free S&H. Quote Link to comment Share on other sites More sharing options...
dadrett Posted January 5, 2012 Author Report Share Posted January 5, 2012 On 1/5/2012 at 2:39 PM, kc300c said: Question: are there ribs protruding from the underside of the lens or is the underside lens surface flat?I want to make sure I don't cut in too deeply and damage these ribs (if they are protruding). Look @ first pic in Post #1 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted January 5, 2012 Report Share Posted January 5, 2012 (edited) If it helps ya, I found that the smd 5050 leds are a decent amount brighter. Here's a link to the style I purchased. I purchased both types and compared them. http://www.ebay.com/itm/2pcs-31mm-DE3022-DE3175-4-SMD-5050-LED-Bulb-Xenon-White-6428-6430-/260869112887?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3cbd02c437 Edited January 5, 2012 by fishx65 Quote Link to comment Share on other sites More sharing options...
fishx65 Posted January 5, 2012 Report Share Posted January 5, 2012 Those puddle lamp leds will be really bright but they might be to wide to fit. Hope they work for ya! I've got the same ones you ordered for my plate/maps and they are really nice. Make sure you let us know how those reverse leds work out. Did you order the festoons for the cargo light and rear dome yet? The ones I got from Dealextreme are awesome. Quote Link to comment Share on other sites More sharing options...
