John 2013 Edge Posted December 3, 2024 Report Share Posted December 3, 2024 Hello. I have a 2013 Edge Limited AWD and I’m going to replace the ABS module due to the sticky bypass valve issue. I understand I will need to program it, and that the traditional way to do that is with a VCM and Ford IDS. It would seem however that VCM units are all but unavailable. I can find plenty of info that J2534 with FRDS will work for 2018+, and some info that J2534 with FJDS will communicate with the older units like mine, but no confirmation that I would be able to use J2534 to program the new ABS/HCU module. I have the engine/trans assy out currently due to water pump and other maintenance, I figure I’ll change out the brake system items (hcu, booster) while I’m here. Can someone point me to a scan tool I should buy to do this? Will FJDS and a unit such as the Mongoose Plus or the CarDAQ Plus-3 program my new unit? Thanks 1 Quote Link to comment Share on other sites More sharing options...
John 2013 Edge Posted December 3, 2024 Author Report Share Posted December 3, 2024 Ok I’ve found this: https://www.motorcraftservice.com/diagnostic/Support?channelId=46&categoryId=286 Which says that the FJDS should be able to program modules but it uses the terminology “SELECT” vehicles which makes me nervous. Would love to hear from someone who knows. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
John 2013 Edge Posted December 3, 2024 Author Report Share Posted December 3, 2024 And a final revelation; it looks like the “select” term applies to 2018+ models only. So I guess my question is can I use FJDS to program my new 2013 ABS module? Thanks 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted December 4, 2024 Report Share Posted December 4, 2024 (edited) FJDS provides module reprogramming software that covers 1996 to select 2018 Ford, Lincoln and Mercury module reprogramming functions, plus complete dealership level diagnostic software for all 2018 to present Ford and Lincoln vehicles. FJDS is designed for use with J2534 compatible Vehicle Communications Interfaces (VCI) including Ford diagnostic hardware (VCM II, or VCMM). The FJDS software license includes time based access to the FJDS software, software updates and calibration files. The following vehicles are supported by FDRS 2018+ Expediion/Navigator 2018+ Ecosport 2019+ Ranger 2020+ Transit 2019+ Transit Connect 2020+ Explorer/Aviator 2020+ Super Duty 2020+ Escape/Corsair 2021+ F-150 2021+ Edge/Nautilus 2021+ Mach-E All other vehicles are supported by IDS/FJDS Edited December 4, 2024 by Wubster100 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted December 4, 2024 Report Share Posted December 4, 2024 If it were me, I would use a third party software, FORScan, to reprogram the ABS module. Quote Link to comment Share on other sites More sharing options...
John 2013 Edge Posted December 4, 2024 Author Report Share Posted December 4, 2024 Just now, Wubster100 said: If it were me, I would use a third party software, FORScan, to reprogram the ABS module. Are we certain this would work? If so, what hardware is required? Quote Link to comment Share on other sites More sharing options...
