2010 Edge AWD indicator?
whiffle
  • 2 months later...
A little late, but just in case you didn't find an answer elsewhere.
There is an AWD indicator on the instrument cluster; its icon is a wrench, and indicates that there's a problem with the power train or AWD system. Its a fault indicator, & it only illuminates when there's a problem (such as the AWD has been overworked, is overheated and is off until it cools.)
