Chipster Posted Saturday at 02:31 PM Report Share Posted Saturday at 02:31 PM This seems to be focused on 2016 3.5 equipped Edges but I am not sure about that. I am wondering if this so called software "fix" will degrade performance and or long term drivability? I expect it's too early for anyone here to have had the recall performed, but when you do (if you do) please respond to this thread with any changes you might notice with your Edge. Seems odd that it only seems to be targeting the 2016 model year and that if there were an emission issue that it would only be known about now? Quote Link to comment Share on other sites More sharing options...
Haz Posted Saturday at 03:32 PM Report Share Posted Saturday at 03:32 PM The original Forum announcement with Dealer Bulletin details... Emission Recall 24E10 - Certain 2015-2018 Edge with 3.5L Engine - Reprogram Powertrain Control Module (PCM) 38 minutes ago, Chipster said: Seems odd that it only seems to be targeting the 2016 model year and that if there were an emission issue that it would only be known about now? The Owner Letter you received mentions only "2016" because that's the Model Year of your Edge. I expect the "over time" revelation of the problem is why 2015-2018 Edges are now subject to the Recall. I do look forward to your personal assessment of the updated PCM software's affect upon your Edge's drivability! Good luck! 2 Quote Link to comment Share on other sites More sharing options...
Cobra4fun Posted Tuesday at 01:57 AM Report Share Posted Tuesday at 01:57 AM Have a 2018 Ford Edge Titanium with the 3.5L in our family fleet and received the same recall. interested to see if this could have ruined our catalytic converters as our check engine light went on and it could only be resolved with a new Front bank catalytic converter. Shop said both converters were bad and not passing the before and after temperature test, but I only replaced the front one as that was the bank the code was triggering. This was after trying to replace both O2 sensors on that bank. Quote Link to comment Share on other sites More sharing options...
Chipster Posted Tuesday at 07:53 PM Author Report Share Posted Tuesday at 07:53 PM (edited) 17 hours ago, Cobra4fun said: Have a 2018 Ford Edge Titanium with the 3.5L in our family fleet and received the same recall. interested to see if this could have ruined our catalytic converters as our check engine light went on and it could only be resolved with a new Front bank catalytic converter. Shop said both converters were bad and not passing the before and after temperature test, but I only replaced the front one as that was the bank the code was triggering. This was after trying to replace both O2 sensors on that bank. That is a good question! What is your average daily MPG? Mine is a little over 24 MPG in around town driving and a little bit better doing over the open road driving. I wish I had an idea as to what the end result will be after the recall work in terms of drivability, and performance. Edited Tuesday at 07:54 PM by Chipster Quote Link to comment Share on other sites More sharing options...
