Problems MS CAN Ford Edge 2022
Hopefully someone can post the wiring diagram for those missing modules and you can see the MS-Can bus and where it might not be terminated or open. Seems like they are all on the left side of the vehicle or the wiring is routed on that side.
I had to remove the existing profile for my vehicle and rescan it to get all the modules to show up. I used a different OBD-II adapter with a switch across bluetooth and it didn't get them all.
Additional information attached below as PDF documents...
Please let me know if any observed Diagnostic Trouble Code (DTC) or Symptom(s) indicates any Diagnostic Pinpoint Test(s) that may be useful toward your efforts, and I will supply.
Good Luck!
Controller Area Network (CAN) Module Communications Network - System Operation and Component Description - 2022 Edge Workshop Manual.pdf Controller Area Network (CAN) Module Communications Network - Diagnosis and Testing - 2022 Edge Workshop Manual.pdf
Are you tracking down several failures or issues? Was the car in an accident or flooded or something else?
I wonder where connector C900 is located and what the pin assignments are.
All the items you list are on page 8 of the MCN document. On page 7 you can see the pins and connector (c900) that go to all those modules from the shared bus from the Gateway module.
I don't have a heated steering wheel so that is why the HSWM is not found for me. Before I removed the saved config I only got about 2/3s of the modules.
  • Thanks 1
Attached below as PDF documents...
Please note that Inline Connector C900 pinout document lacks these circuit descriptions for Module Communications-related pins:
Good luck!
Inline Connector C900 - Location View 1 - 2022 Edge.pdf Inline Connector C900 - Location View 2 - 2022 Edge.pdf Inline Connector C900 - Location View 3 - 2022 Edge.pdf Inline Connector C900 - Pin-Circuit Alpha-Numeric Identifier - 2022 Edge.pdf
