vyzr Posted October 20, 2024 Report Share Posted October 20, 2024 (edited) Hi everyone, One of my front turn signal bulbs burnt out on my 2019 Edge SEL. I went on Amazon and it said a 7440 bulb would be the replacement, so I ordered a pair of 7440 Yellow LED bulbs with built-in resistors. When I tried to change them tonight, I twisted the socket out, and then bulb that pops out of it is NOT a 7440 bulb. So I checked the user manual and it says it requires a WY21W bulb, which upon further investigation, is the same base as a 7440 bulb. Anyways, the bulb that's in my turn signal socket is some weird bulb I've never seen before and there are no identifying marks on it. I did some forum searching and found out that there are possibly three types of Edge SEL light housings, so maybe mine are the weird type? Would anybody know what this particular bulb is? Thanks in advance! Edited October 20, 2024 by vyzr 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 20, 2024 Report Share Posted October 20, 2024 I don't see any LED replacements for that bulb type. Signal Lamp Bulb - Ford (DS7Z-13466-A) 3 Quote Link to comment Share on other sites More sharing options...
vyzr Posted October 20, 2024 Author Report Share Posted October 20, 2024 (edited) @1004ron Oh my gosh, thank you so much! The exact bulb! I did a search for that part number and the LED replacements showed up on Amazon! The base of the bulb appears to be the exact same. https://www.amazon.com/iJDMTOY-360-Degree-Compatible-European-Vehicles/dp/B00QN1WAPS/ Edited October 20, 2024 by vyzr 3 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted October 21, 2024 Report Share Posted October 21, 2024 I will have to triple check the base before I replace my turn signal bulbs. Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 21, 2024 Report Share Posted October 21, 2024 You can disable the hyperflash with Forscan and change them to Turn Signal Only, not Park & Turn Signal. The ForScan changes were: 726-29-02 xxx* xxxx xxxx 0=Turn Only 1=Turn & Parking/Position 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted October 21, 2024 Report Share Posted October 21, 2024 Unfortunately it looks like 2019+ owners manual wasn't updated for exterior bulbs from previous generation. It still shows halogen headlamps and HID available (and DRL), that turn bulb (which is a turn only) also is shown as the older one. 1 Quote Link to comment Share on other sites More sharing options...
vyzr Posted October 22, 2024 Author Report Share Posted October 22, 2024 8 hours ago, 1004ron said: You can disable the hyperflash with Forscan and change them to Turn Signal Only, not Park & Turn Signal. The ForScan changes were: 726-29-02 xxx* xxxx xxxx 0=Turn Only 1=Turn & Parking/Position This is great info, thank you so much! A few weeks ago I actually upgraded to an H7 AGM Odyssey battery after the stock 2019 Motorcraft battery failed, and I used Forscan to update the BMS info to an "02" battery. I'll have to disable hyperflash as well if the built-in resistors on the bulbs don't work. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted October 23, 2024 Report Share Posted October 23, 2024 I have my halogen turn signals set to be turn signals, but I used FORScan to set the running lights to do the same thing as the DRL. I thought from the factory the turn signal bulbs are only for turn signals and running lights, but I have seen another Edge on the road and the turn signals also functioned as running lights. Did something change with the turn signals throughout 2019-2024? From the factory my turn signals never operated as running lights. Quote Link to comment Share on other sites More sharing options...
vyzr Posted October 30, 2024 Author Report Share Posted October 30, 2024 (edited) Just wanted to do a follow up post, I got the turn signals and installed them. These are the ones I purchased: https://www.amazon.com/AUXITO-7440-Resistor-Blinker-Replacement/dp/B0CLP6N7SX?th=1 edit: https://www.amazon.com/Resistor-Extremely-Blinker-Replacement-Upgraded/dp/B09S9WGSWY They are comically bright compared to the stock bulbs. I wouldn't know how to describe the difference in lumen output, but the stock bulbs are kind of a soft, hard to see glow, whereas these new LED bulbs are akin to laser beams, seemingly at least twice as bright as the stock ones and just pierce the very fabric of your soul when you stare at them. No hyperflashing either! Here's a video at night. IMG_7493.MOV Edited October 30, 2024 by vyzr 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted October 30, 2024 Report Share Posted October 30, 2024 So even though the original WY21W 7440 based bulbs you got didn't fit, others did? It doesn't take the PWY24W bulb like the Fusion? Quote Link to comment Share on other sites More sharing options...
vyzr Posted October 30, 2024 Author Report Share Posted October 30, 2024 (edited) I apologize, @dabangsta, I totally mucked up that post and put the INCORRECT bulbs. THESE are the bulbs I got that CORRECTLY fit my 2019 Edge SEL https://www.amazon.com/Resistor-Extremely-Blinker-Replacement-Upgraded/dp/B09S9WGSWY The ones I incorrectly posted above https://www.amazon.com/AUXITO-7440-Resistor-Blinker-Replacement/dp/B0CLP6N7SX?th=1 were the ones I had originally ordered (due to the user manual and Amazon stating they were what I needed) and DID NOT fit. So yes, it DOES take the PWY24W bulb like the Fusion. Sorry for the con"Fusion"... <--- see what I did there? I'm cool like that. Edited October 30, 2024 by vyzr Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted November 1, 2024 Report Share Posted November 1, 2024 I can't see the video 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 4, 2024 Report Share Posted November 4, 2024 Thanks for the update on the PN and the ones you got! I have had these for awhile, I bought them for my 2015 Fusion that my daughter drives, but didn't get them installed before she had the bulbs replaced for way too much money. $3.50 for the set from China (Aliexpress), I will install them when I remove the drivers side headlight assembly to install the dual tone horn. 1 Quote Link to comment Share on other sites More sharing options...
vyzr Posted November 4, 2024 Author Report Share Posted November 4, 2024 On 11/1/2024 at 5:28 PM, Wubster100 said: I can't see the video Hmmm I had originally uploaded from my iPhone.... Let me convert it from MOV to MP4 and re-upload. @Wubster100 Hopefully you can see this? IMG_7493.mp4 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted November 6, 2024 Report Share Posted November 6, 2024 Thanks, I can see the video now. Have you tried using them as marker lights too? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 6, 2024 Report Share Posted November 6, 2024 9 hours ago, Wubster100 said: Thanks, I can see the video now. Have you tried using them as marker lights too? You mean in Forscan enable them to be always on until used as a turn signal, then blink? By default I don't think any models have the inner light as a marker/parking light, just the outer, and possibly the signature lighting (LED strip). 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted November 7, 2024 Report Share Posted November 7, 2024 Yes. I have seen other Edges on the road with the turn signal lights also lit up as marker lights. I’m not sure what models have that as factory, because I think it also had the white DRLs. 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 7, 2024 Report Share Posted November 7, 2024 Seems like 2015+ that bulb is directional only. 2007-2014 it was a combo park/directional, with park being lower powered than the directional (so it was always on when park/headlights on even when blinking). The directional can be set to be the DRL in Forscan. The LEDs I tried fast blink (the IC only, not the actual bulbs), which was annoying but I might try setting them to DRL to see if they properly blink on turn signal usage. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted November 8, 2024 Report Share Posted November 8, 2024 12 hours ago, dabangsta said: Seems like 2015+ that bulb is directional only. 2007-2014 it was a combo park/directional, with park being lower powered than the directional (so it was always on when park/headlights on even when blinking). The directional can be set to be the DRL in Forscan. The LEDs I tried fast blink (the IC only, not the actual bulbs), which was annoying but I might try setting them to DRL to see if they properly blink on turn signal usage. 2015-2018 is also combo. Position+Direction light. However, for these years it uses a single filament bulb and changes the voltage to change from position lights to signal. On my 2016 I had the position lights disabled with ForScan (link here) so they function as turn signal lights only. For park we have the bumper mounted "signature" lights. 2 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 8, 2024 Report Share Posted November 8, 2024 Sorry, yes, I was confused about the 2015-2018 until I found a video on them and tracked down my neighbor to check out theirs, I was going to retract what I said. I guess I would like to find a non signature lighting 2019+ headlight to see what it has, this is my first Ford with signature lighting that isn't always on (it can be turned off with the light switch in the off position), all others no matter what, if the car is in RUN position the signature lighting is on. 1 Quote Link to comment Share on other sites More sharing options...
