kevin kogut Posted October 15 Report Share Posted October 15 I have a 2019 edge 1.5l fwd, I got codes p0137 and p0138 so i know it bank 1 sensor 2 oxygen sensor. I want to change it myself and know its after the converter. Can i get to it without removing major parts? 1 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted October 15 Report Share Posted October 15 Welcome to the Forum, @kevin kogut! Presumably, your Edge is a 2.0L EcoBoost rather that a 1.5L. Attached below as PDF documents are the Workshop Manual procedure and info on the recommended special tool... Good luck! Catalyst Monitor (Oxygen) Sensor - Removal and Installation - 2019 Edge Workshop Manual.pdf Exhaust Gas Oxygen Sensor Socket - Rotunda Part Number 303-476.pdf 2 Quote Link to comment Share on other sites More sharing options...
kevin kogut Posted October 15 Author Report Share Posted October 15 I'm sure its a 1.5L 1 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted October 15 Report Share Posted October 15 So you have an Escape not an Edge. Since the Edge has never had the 1.5 that is where the confusion was. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted October 15 Report Share Posted October 15 (edited) Get back to https://fordescapeforum.com/! 😂 ...Doesn't look like there is too much activity going on over there. Edited October 15 by Wubster100 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 15 Report Share Posted October 15 17 hours ago, kevin kogut said: I have a 2019 edge Get your money back - they charged you for the wrong vehicle. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 15 Report Share Posted October 15 1 hour ago, kevin kogut said: I'm sure its a 1.5L Add your location and vehicle Model & Year to your profile signature - https://www.fordedgeforum.com/settings/signature/ 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted October 16 Report Share Posted October 16 @kevin kogut: As before, attached below as PDF documents are relevant sections from the 2019 Escape Workshop Manual... Please be aware that some numbered action-step descriptions may appear at the bottom of the page before the illustration to which it applies. 1.5L EcoBoost Engine Item Description 1 Turbocharger bypass valve solenoid 2 CMP sensor RH exhaust 3 ECT sensor 4 HO2S 5 Catalyst monitor sensor 6 CHT 2 (CHT2) sensor 7 CKP sensor 8 Wastegate actuator 9 VCT oil control solenoid exhaust Good luck! Catalyst Monitor (Oxygen) Sensor - 1.5L EcoBoost - Removal and Installation - 2019 Escape Workshop Manual.pdf Air Cleaner Outlet Pipe - 1.5L EcoBoost - Removal and Installation - 2019 Escape Workshop Manual.pdf Battery Tray - 1.5L EcoBoost - Removal and Installation - 2019 Escape Workshop Manual.pdf Exhaust Gas Oxygen Sensor Socket - Rotunda Part Number 303-476.pdf 1 Quote Link to comment Share on other sites More sharing options...
