2014 Ford Edge awd front end noise
Ford guy77
I’ve owned the 2014 Ford Edge about 6 months now. First thing driving in the morning, squealing noise starts up coming from front of vehicle. It only lasts about a minute then goes away. I don’t hear again unless the vehicle sits for a few hours without being driven. One mechanic looked at it and couldn’t figure out noise. PTU fluid was fine but was changed. No leaking from the ptu.
  • 2 months later...
Belts will squeal when wet. As the run the get, dry out and stop.
As it occurs when the belts are cold, an accessory belt would be my first suspect.
Any possibility that its coming from inside the cabin and just sounding like its coming from the engine compartment?  An hvac motor will squeal when the lubrication is dry. As it continues to run, it picks up some lube and stops squealing. Mine did this. Very sporadic, finally narrowed it down. Pulled it and ran superb into the bearings. Been at least five years now and not a peep.
