JPJMustang Posted October 7, 2024 Report Share Posted October 7, 2024 (edited) looking to change the timing chain & ...... Are there any recommendations for kits and what should I have in the kit? And for my information - did they put different 3.5s in these - or are they all the same? JPJM Edited October 7, 2024 by JPJMustang Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 3, 2024 Report Share Posted November 3, 2024 AFAIK there are two different 3.5 L engines, one that faces forward with an external water pump and the the other a transverse (as in the Edge) with an external water pump. As far as the 14 parts in a kit, you can check out this kit for what's included. Not recommending as it's not Motorcraft, and I'd only use Motorcraft, but gives you a good idea as to what's included. https://www.partsgeek.com/4zlxl33-ford-edge-timing-chain-kit-and-water-pump.html While you're tearing down the engine, I'd also go with new plugs, new coil skirts & new EGR. Quote Link to comment Share on other sites More sharing options...
Cerberus Posted November 6, 2024 Report Share Posted November 6, 2024 On 11/3/2024 at 6:12 PM, enigma-2 said: AFAIK there are two different 3.5 L engines, one that faces forward with an external water pump and the the other a transverse (as in the Edge) with an external water pump. As far as the 14 parts in a kit, you can check out this kit for what's included. Not recommending as it's not Motorcraft, and I'd only use Motorcraft, but gives you a good idea as to what's included. https://www.partsgeek.com/4zlxl33-ford-edge-timing-chain-kit-and-water-pump.html While you're tearing down the engine, I'd also go with new plugs, new coil skirts & new EGR. I'm betting you meant external and internal, not external and external 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 6, 2024 Report Share Posted November 6, 2024 2 hours ago, Cerberus said: I'm betting you meant external and internal, not external and external Ummmmm, let's compromise. I'll say I was wrong if you admit I was right. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted November 6, 2024 Report Share Posted November 6, 2024 2 hours ago, Cerberus said: I'm betting you meant external and internal, not external and external Ummmmm, let's compromise. I'll say I was wrong if you admit I was right. 😁 1 Quote Link to comment Share on other sites More sharing options...
