FordGuy309 Posted October 3, 2024 Report Share Posted October 3, 2024 I have a 2007 Edge, the OEM fluid pump housing is cracked and is slowly leaking. No problem, ordered the part, looked up how to replace it. Got the new pump in, new hoses to the front wipers. hit the switch and nothing, I can hear the pump running and the rear spray works. Put the old pump back on and everything works. I figured I was the lucky recipient of a faulty pump. Ordered another pump, from another vender. (Both off Amazon, and both are supposed to be direct OEM replacements). Just went out and put the new pump in and I have the same issue. I wouldn't think that I was that unlucky to get two faulty pumps... What am I missing? Quote Link to comment Share on other sites More sharing options...
garycrist Posted October 3, 2024 Report Share Posted October 3, 2024 If you have rear washer and no front, then the front squirters are probably plugged up and it"s time to get a new pair. Quote Link to comment Share on other sites More sharing options...
FordGuy309 Posted October 3, 2024 Author Report Share Posted October 3, 2024 I have the nozzles unhooked at the moment. Quote Link to comment Share on other sites More sharing options...
FordGuy309 Posted October 4, 2024 Author Report Share Posted October 4, 2024 Well I guess that is what I get for trying to save a dollar or 2. Ran down to auto store and bought one, and it works fine. Should of known better. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted October 4, 2024 Report Share Posted October 4, 2024 Thank You @FordGuy309 for helping the next person that as a washer problem. Once more buying junk parts from Amazon is a BIG CRAP SHOOT that might work errr most of the times... Quote Link to comment Share on other sites More sharing options...
