DSL6830 Posted October 3, 2024 Report Share Posted October 3, 2024 My Edge will reach operating temperature like normal for the most part. But will drop while driving on the highway. Note it's hot and the ac is on max. and even when its off this issue is consistent. Sometimes I feel a thud while driving and the oil will be at normal temp for a while. But then drops. When my edge is having this issue running cold its a lot slower and louder. The thermostat has been replaced for the same issue earlier this year. I can't figure out what the issue is but i would like my car to last a while longer. Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 3, 2024 Report Share Posted October 3, 2024 Welcome. What brand thermostat did you use? The thermostat is the likely cause of the low coolant temperature when at speed, and don't think its related to some of the other issues you describe. Quote Link to comment Share on other sites More sharing options...
DSL6830 Posted October 3, 2024 Author Report Share Posted October 3, 2024 I'm not sure ford did it. Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 3, 2024 Report Share Posted October 3, 2024 Quote The thermostat has been replaced for the same issue earlier this year. Did it resolve the issue at that time? If it did, then its more confirmation that its failed again - these days they're designed to "fail open". Quote Link to comment Share on other sites More sharing options...
DSL6830 Posted October 3, 2024 Author Report Share Posted October 3, 2024 It helped. But was not fixed all the way. It stopped the timing chin from falling loose. Quote Link to comment Share on other sites More sharing options...
