Haz Posted October 3, 2024 Report Share Posted October 3, 2024 SSM 53018 2021-2024 Various Vehicles - DTCs U2100 And/Or U3002 Stored In CCM, SODL, SODR, SODCMC, And/Or SODCMD Some 2021-2024 Ford and Lincoln vehicles may exhibit diagnostic trouble codes (DTCs) U2100 and/or U3002 stored in the cruise control module (CCM), side obstacle detection control module LH (SODL), side obstacle detection control module RH (SODR), side obstacle detection control module C (SODCMC) and/or side obstacle detection control module D (SODCMD) after a module replacement. DTC U2100 may set when the module has not been properly configured after replacement. DTC U3002 may set when the module has been configured with the incorrect VIN. To correct this condition, verify that the module storing the DTC has been installed following the applicable Workshop Manual (WSM) Removal and Installation procedure. If the DTC is still stored, download and run the Vehicle Identification Number (VIN) Write application found under Toolbox, Multi-Module tab in the Ford Diagnosis and Repair System (FDRS). Module Configuration information from the Workshop Manual... Placing your device cursor over underlined acronyms may yield popup full-words descriptions of acronyms. Programmable Module Installation (PMI) PMI is a diagnostic scan tool process which configures settings in a new module. Data used for the PMI process is automatically downloaded from the original module and stored when a diagnostic scan tool session is started. If this data cannot be retrieved from the module being replaced, the diagnostic scan tool may prompt for Configuration data entry or display a list of parameter values that need to be manually selected. Some modules are reprogrammed during PMI when a strategy/calibration update is available. It is important the diagnostic scan tool identifies the vehicle and obtains configuration data prior to removing any modules. The new module must be able to communicate with the diagnostic scan tool in order to carry out PMI . Module Reprogramming Module reprogramming (also referred to as flashing) is a diagnostic scan tool process which updates the strategy/calibration in a module. Reprogramming a module with the same level of software does not improve module operation or repair a hardware failure. Module reprogramming is automatically carried out during PMI when a later strategy/calibration is available. Limit module reprogramming to circumstances where a published TSB , GSB , SSM or FSA recommends doing so. A module cannot communicate with other modules on the communication network while being reprogrammed. After the reprogramming process, clear any network communication Diagnostic Trouble Codes (DTCs) which may have been set in other modules. Some modules are reprogrammed in coordination with other modules. The following modules with an Ethernet connection can be reprogrammed using a diagnostic scan tool and USB flash drive: APIM , GWM and TCU . Programmable Parameters Programmable parameters are customer preference items that may be modified by the dealer via the diagnostic scan tool, or in some cases, modified by the customer following a procedure listed in the Owner Literature. While many configuration options may exist for a module, only a few of these options are programmable parameters. Some parameters must be changed in multiple modules at the same time. Adaptive Learning and Calibration Some modules require a separate learning procedure be carried out if replaced as part of a repair procedure. For adaptive learning and calibration instructions, refer to the specific module removal and installation procedures. Direct Configuration Data (formerly known as VID block) The direct configuration data commonly stores powertrain configuration items such as tire size, axle ratio, and whether or not the vehicle is equipped with cruise control. Configuration data is a VIN -specific module configuration record. During vehicle build, the configuration from all modules is downloaded and stored in the configuration database. Configuration data does not reflect customer preference items that have been changed from the default state. These items need to be changed using programmable parameters after the module is configured. It is not necessary to obtain configuration data unless directed to do so by the diagnostic scan tool. This data may be accessed from the PTS web site. VIN-specific (As-Built) module configuration is also available from this Ford Service website after you designate your Country and Language. 1 Quote Link to comment Share on other sites More sharing options...
