Cmd511 Posted October 2, 2024 Report Share Posted October 2, 2024 (edited) Good Afternoon everyone, sorry if this has been posted anywhere but just wanted some advice. I have a 2008 ford edge and I think the oss/tss sensors might be on their way out. It hasn’t done the typical ODO data error or gone into limp mode. But it does do a very large clunk when going from park to reverse or from drive to reverse. Also I’ve started noticing recently that at lower speeds when you then push down on the accelerator a clunk type feeling happens and also when slowing down as if the speed and the gears are not really matching one another? Also in the last couple of days it’s started surging and slipping a bit (looked at the trans oil and it looks a little brown so will try and flush that out this weekend). I’ve previously changed all 3 engine mounts and 2 of them were completely dead. Thank you! Edited October 3, 2024 by Cmd511 2 Quote Link to comment Share on other sites More sharing options...
garycrist Posted October 3, 2024 Report Share Posted October 3, 2024 I have one of those too.(08) They had a funky shift learning curve. Changing from 1 driver as primary, to another driver will cause it fits. Have you tried a battery disconnect on it yet? Quote Link to comment Share on other sites More sharing options...
Cmd511 Posted October 3, 2024 Author Report Share Posted October 3, 2024 23 minutes ago, garycrist said: I have one of those too.(08) They had a funky shift learning curve. Changing from 1 driver as primary, to another driver will cause it fits. Have you tried a battery disconnect on it yet? I’ll give it a go! I hadn’t for a while! 1 Quote Link to comment Share on other sites More sharing options...
