jeldridge Posted October 2, 2024 Report Share Posted October 2, 2024 Hey guys. I purchased a 2013 Edge a few months ago and so far I'm really loving it. The only complaint I have is the disappointing lack of "get up and go". I know this wasn't meant to be a speed demon, and I'm not expecting it to be. I just wish it had a little bit of zip when I hit the gas. When I give it a little extra, say I'm trying to pass someone on a two lane, it gets louder but doesn't really accelerate that quickly. Just to put things in perspective, my wife drives a 2015 Acura MDX. When you give that thing gas, it takes off! Again, I know my Edge isn't a Mustang, lol. Just wanting to give it a little pep. I've thought about a performance chip, but wondered if it was worth it? Do any of you have one, and could you tell much of a difference? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted October 2, 2024 Report Share Posted October 2, 2024 What model and engine? If it is the 2.0 Ecoboost engine it is about 50hp down from the MDX (but more torque at a lower rpm), the 3.5 would be similar in HP but lower in torque. The 3.7 had better of both. But HP and torque are just a part of the equation. The 2.0 is more reactive to mods and tunes. It might be more of a perception difference and more responsive shifting (tried Sport mode?) that might be able to helped with a tune, instead of just adding power. I can't find the final gearing for the Edge but I don't think it is as high as the MDX. Also you might be more likely to be running premium fuel in the MDX? There is some seat of the pants differences running premium over regular. 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 27, 2024 Report Share Posted October 27, 2024 On 10/2/2024 at 3:21 PM, dabangsta said: Also you might be more likely to be running premium fuel in the MDX? There is some seat of the pants differences running premium over regular. Its my understanding that all grades of gasoline have exactly the same heat energy and using premium does nothing to increase hp. On engines designed for premium, using regular will drop hp slightly as they were designed for premium. (Higher compression.) But engines designed for regular wont benefit from premium. (As I understand it, premium may mask the knock sensor signal and cause the engine run too lean.) Quote Link to comment Share on other sites More sharing options...
akirby Posted October 28, 2024 Report Share Posted October 28, 2024 On 10/26/2024 at 11:30 PM, enigma-2 said: Its my understanding that all grades of gasoline have exactly the same heat energy and using premium does nothing to increase hp. On engines designed for premium, using regular will drop hp slightly as they were designed for premium. (Higher compression.) But engines designed for regular wont benefit from premium. (As I understand it, premium may mask the knock sensor signal and cause the engine run too lean.) It depends on whether the engine software is designed to take advantage of higher octane by advancing the timing. Thats where the extra power comes from - has nothing to do with the fuel per se. Quote Link to comment Share on other sites More sharing options...
