2017 Ford edge not shifting into gear
Ashley S
There is a recall on the shifter bushing. If it breaks or disconnects, then the shifter is no longer connected to the transmission, and could cause what you are reporting.
You should look up recalls by VIN on the Ford or NHTSA sites to see if it is outstanding or has been done. I had my 2015 Fusion done, and it broke again, and they had a revised part for it later on.
https://static.nhtsa.gov/odi/rcl/2022/RCMN-22V413-1296.pdf
It is an easy fix on most vehicles, the fix and other circumstances might make it a mobile repair, I personally would verify that is what is happening to not have to pay a $180-350 diagnostic fee, and if it isn't the recall, owe that.
  • Thanks 2
