Special Service Messages 52967/52980 - 2024 Nautilus + Other Models - Passive Key Will Not Program/One Passive Key Does Not Start The Vehicle, RKE Button Functionality Works
Haz
SSM 52967   Various Ford And Lincoln Vehicles - Passive Key Will Not Program
Some of the following vehicles may exhibit a condition where the passive key will not program to the vehicles:
* 2024 F-150 non-Lightning
* 2023-2024 F-Super Duty
* 2025 Explore/Aviator
* 2024 Nautilus
* 2024 Mustang vehicles built on or after 31-May-2024
* 2024 Bronco vehicles built on or after 01-June-2024
If a key does not program, rotate the key 180 degrees in the passive key backup starting location versus what is recommended in the Owners Manual Section > "Starting and Stopping the Engine - Accessing the Passive Key Backup Position" and then reattempt programing. If the key still does not program, refer to Workshop Manual (WSM), Section 419-01 for normal diagnostics.
SSM 52980   Various Ford And Lincoln Vehicles - One Passive Key Does Not Start The Vehicle, RKE Button Functionality Works
Some of the following vehicles may exhibit one passive key that is unable to start the vehicle or activate the passive entry feature; however, all remote keyless entry (RKE) physical button functionality works correctly and the second passive key will have full/correct functionality (including being able to start the vehicle):
* 2024 Nautilus
This may be due to a partial programming of a passive key from the factory. To correct this condition, use the Ford Diagnosis and Repair System (FDRS) scan tool to erase all keys and then program all keys back to the vehicle. Refer to the Workshop Manual, Section 419-01. If a key fails to program, rotate the key 180 degrees in the passive key backup starting location versus what is recommended in the Owners Manual Section > "Starting and Stopping the Engine - Accessing the Passive Key Backup Position" and then reattempt programing. For claiming, use causal part 15K601 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual.
