Help with Shifter cable lever
ProjectPat
My cable for my shifter came disconnected from the lever of the transmission. I bought a new bushing and everything seemed fine, then it slipped again. So I looked further into it, and it seems like the nipple on the lever that attaches to the transmission might be the problem but I am having trouble finding a replacement lever.  Any help would be much appreciated
Welcome to the Forum @ProjectPat!
Are you certain the cable-end locking clip is fully engaged after you mount the shifter cable onto the ball stud of the manual shifter lever, as depicted below?...
ManualShiftLever-6F35Transmission-Illustration-2013EdgeWorkshopManual.thumb.jpg.9ccffb6cd24e73d69b090acb7319c3c5.jpg
  1. Carefully pry outward the adjuster lock tabs.
  1. While holding the adjuster lock tabs outward, slide the lock to unlock the selector lever cable...
SettingLockingClipOnShiftCableInUnlockedPosition-6F35Transmission-Illustration-2013EdgeWorkshopManual.thumb.jpg.35afcd335ecb829eeefd15dc209ee39f.jpg
NOTICE: To prevent selector lever cable damage, do not apply force to the selector lever cable between the manual control lever and the selector lever cable bracket.
NOTE: Make sure that the selector lever cable end is correctly installed onto the manual control lever ball stud by pulling back on the selector lever cable end...
InstallingShiftCableEndonManualShiftLever-6F35Transmission-Illustration-2013EdgeWorkshopManual.thumb.jpg.398bdce2e17e2ede5534e61cbee10770.jpg
NOTE: After locking the adjuster, pull back on the adjuster to make sure it is securely installed...
SettingLockingClipOnShiftCableIntoLockedPosition-6F35Transmission-Illustration-2013EdgeWorkshopManual.thumb.jpg.a6f5c0087a28e7c32ae5c95577da13ad.jpg
This 2013 Edge Workshop Manual procedure is also attached below as a PDF document...
Good luck!
Selector Lever Cable Adjustment — 6F35 - General Procedures - 2013 Edge Workshop Manual.pdf
