BamaInArk Posted September 20, 2024 Report Share Posted September 20, 2024 I just purchased a used 2020 Edge SEL AWD. I now noticed the drivers side fog light does not work. On close inspection it is full of water. I can bang on the assembly and get it to flicker. For the life of me I cannot find an easy way to access the fog light assembly. Where can I find any instructional material on disassembly/reassembly? I suspect I might have to remove some of the front bumper trim, wheel well, etc to access. At the very least I need to remove and reseal it to keep the moisture out. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 21, 2024 Report Share Posted September 21, 2024 Welcome to the forums @BamaInArk Attached you will find a Youtube video and other information on removing the front bumper to access the fog lights. https://youtu.be/4ZjwjQ5wTEE?si=s8BYQ6mhI80Soz6- https://www.fordedgeforum.com/topic/33062-general-service-bulletin-24-7068-various-vehicles-exterior-lighting-concern-analysis/ BODY CONTROL MODULE (BCM) - Connector C2280B Details - 2019 Edge.pdf FOG LAMP, LEFT FRONT - Connector C152 Details - 2019 Edge.pdf FOG LAMP, RIGHT FRONT - Connector C162 Details - 2019 Edge.pdf Fog Lamps - Diagnosis and Testing - 2019 Edge Workshop Manual.pdf Fog Lamps Power Circuit - Pins 15 (LH) & 16 (RH) of Inline Connector C140 - 2019 Edge.pdf Fog Lamps Wiring Diagram -2019 Edge.pdf Front Bumper Cover - Disassembly and Assembly - 2019 Edge Workshop Manual.pdf Front End Ground Circuits, Including Fog Lamps Ground - Wiring Diagram - 2019 Edge.pdf Front Bumper Cover - Removal and Installation - 2019 Edge Workshop Manual.pdf 2 Quote Link to comment Share on other sites More sharing options...
BamaInArk Posted September 21, 2024 Author Report Share Posted September 21, 2024 Thanks for the input. Looks like a big job just to get to the fog light assembly. Uggggg! 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 21, 2024 Report Share Posted September 21, 2024 It isn’t too terrible to remove the front bumper cover. I would recommend using a power tool to unscrew the small bolts on the bottom and wheel well area. Don’t remove the wheel well cover. Instead, remove the headlights as shown in the video to get to the three silver bolts. Quote Link to comment Share on other sites More sharing options...
BamaInArk Posted September 22, 2024 Author Report Share Posted September 22, 2024 Yeah been wanting to get me a nice 3/8 cordless ratchet tool. Probably the Milwaukee M12 one. As an alternative I did get a good extended warranty($$$$) in case I want to go that route. Quote Link to comment Share on other sites More sharing options...
