EDST777 Posted September 15 Report Share Posted September 15 (edited) Faced now with a problem: on a dirt road, the car shook and the dipped headlights disappeared, drove to the place on fog lights when he removed the key from the ignition, it did not turn off the light of the side lights in front, apparently the contacts in the PCM block stuck. I removed the battery clip for 40 seconds, but it didnt help, I left the car without a clip until the morning. We had such similar problems in the group, what can this be connected with, what can be checked? Please any thoughts... In the spring I had a case when the parking lights did not turn off, then the problem was solved by removing the battery clack and until this time the problem did not manifest. I fear that it is a PCM fault, can be fixed without changing the control unit, can be tested something else ? If you change the control unit, then how to select it from the secondary market, so as to avoid programming. Is it possible to repair the base element of my block of failure? Many questions , please any thoughts. ...also I found information that it may be a problem of the light switch headlamp , which forward Check and how? Edited September 15 by EDST777 Quote Link to comment Share on other sites More sharing options...
