sc00by Posted September 13, 2024 Report Share Posted September 13, 2024 Greetings, I am looking for something which indicates when fluids need to be changed. For example, when would I need to change fluid in any of the systems? I am looking at the owners manual and am not seeing anything about the differentials, PTU or other systems outside of oil. Does someone have a chart of intervals for maintenance needed on the edge? Thanks! 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 13, 2024 Report Share Posted September 13, 2024 It is all right there in the Scheduled Maintenance section. Oil, transmission fluid, coolant, brake fluid. these all have a maintenance interval. Rear Axle and PTU are stated as not having a normal schedule, no maintenance unless submerged in water, severe duty, or a leak is found. Now unofficially most will not follow the normal maintenance schedule, and should follow the severe duty schedule and add the rear diff and PTU, doing fluid changes more frequently and doing them even if not a normally changed item. 3 Quote Link to comment Share on other sites More sharing options...
sc00by Posted September 13, 2024 Author Report Share Posted September 13, 2024 (edited) On 9/13/2024 at 2:53 PM, dabangsta said: It is all right there in the Scheduled Maintenance section. Oil, transmission fluid, coolant, brake fluid. these all have a maintenance interval. Rear Axle and PTU are stated as not having a normal schedule, no maintenance unless submerged in water, severe duty, or a leak is found. Now unofficially most will not follow the normal maintenance schedule, and should follow the severe duty schedule and add the rear diff and PTU, doing fluid changes more frequently and doing them even if not a normally changed item. Expand Please enlighten me on where to find anything about the PTU, diffs, transmission. https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=7056&languageCode=en&countryCode=USA&Uid=G2063585&ProcUid=G2063586&userMarket=USA&div=f&vCode=2FMPK4AP1LBB55974&vFilteringEnabled=True&buildtype=web Edited September 13, 2024 by sc00by Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 13, 2024 Report Share Posted September 13, 2024 On 9/13/2024 at 3:25 PM, sc00by said: Please enlighten me on where to find anything about the PTU, diffs, transmission. https://www.fordservicecontent.com/Ford_Content/vdirsnet/OwnerManual/Home/Content?variantid=7056&languageCode=en&countryCode=USA&Uid=G2063585&ProcUid=G2063586&userMarket=USA&div=f&vCode=2FMPK4AP1LBB55974&vFilteringEnabled=True&buildtype=web Expand Click that right arrow at the lower right, and it shows the severe or special uses interval, and the exceptions that include PTU and rear diff. Transmission is on the main maintenance schedule at 150,000 miles. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted September 13, 2024 Report Share Posted September 13, 2024 What weight fluid goes into the PTU and RDU a 22 ST? Quote Link to comment Share on other sites More sharing options...
Haz Posted September 13, 2024 Report Share Posted September 13, 2024 @garycrist: Fluid specifications and related procedures from 2022-2024 Edge Workshop Manual are attached below as PDF documents... Good luck! Specifications - Rear Drive Axle-Differential - 2022-2024 Edge.pdfFetching info... Differential Draining and Filling - Rear Drive Axle-Differential - 2022-2024 Edge.pdfFetching info... Differential Fluid Level Check - Rear Drive Axle-Differential - 2022-2024 Edge.pdfFetching info... Specifications - Power Transfer Unit - 2.7L EcoBoost - 2022-2024 Edge.pdfFetching info... Power Transfer Unit Draining and Filling - Power Transfer Unit - 2.7L EcoBoost - 2022-2024 Edge.pdfFetching info... Power Transfer Unit Fluid Level Check - Power Transfer Unit - 2.7L EcoBoost - 2022-2024 Edge.pdfFetching info... 3 Quote Link to comment Share on other sites More sharing options...
Haz Posted September 13, 2024 Report Share Posted September 13, 2024 Additional related 2022-2024 Workshop Manual sections attached below as PDF documents... Good luck! Component Location - Rear Drive Axle-Differential - 2022-2024 Edge.pdfFetching info... System Operation and Component Description - Rear Drive Axle-Differential - 2022-2024 Edge.pdfFetching info... Power Transfer Unit - Description and Operation - 2.7L EcoBoost - 2022-2024 Edge.pdfFetching info... 2 Quote Link to comment Share on other sites More sharing options...
