2013 Edge brake problems
AshleysEdge
Well, someone can look up by VIN the build sheet to see how it is equipped, but no part of the VIN can be decoded to show it has ACC. You can try inputting it into parts.ford.com to see if it gives you the part number you need for the correct part for having ACC, I have done that in the past to be able to get the right upgraded brake parts (larger rotors, brackets, and calipers).
This is all that can be decoded via VIN: https://content.fordpro.com/content/dam/fordpro/us/en-us/pdf/fleet-vehicles/vin-lookup-and-guides/2013-vin-guide.pdf without further help. If they show the steering wheel it will have the different controls ACC vs standard.
