2017 Edge SEL Audio/Speaker Issues
To assess the functionality of your Edge's speakers, try using one of the below-attached Bezel Diagnostics procedures to perform a Speaker Walkaround Test.
From the 2017 Edge Workshop Manual, if your Edge SEL is equipped with the AM/FM/CD/SYNC audio system...
Placing your device's cursor over underlined acronyms may yield popup full-words descriptions of the acronyms.
The audio system consists of the following:
Main Components
  • 6 speakers
  • 4.2-inch (107 mm) non-touchscreen FCDIM
  • ACM
  • APIM
  • Audio input jack (if equipped)
  • FCIM
  • USB port/cable
  • GPSM
  • RH steering wheel audio controls
Main Features
  • Audio extended play
  • Battery load shed
  • Compass
  • MyKey®
  • Speed compensated volume
  • SYNC®
  • SYNC® AppLink™
...then use this Bezel Diagnostics procedure...
Bezel Diagnostics - Vehicles With AM-FM-CD-SYNC - 2017 Edge Workshop Manual.pdf
If your Edge SEL is equipped with the Premium Audio 9-Speakers audio system with Touchscreen...
Main Components
  • 9 speakers
  • 8-inch (203 mm) FDIM touchscreen
  • ACM
  • APIM
  • FCIM
  • USB hub
  • RH audio steering wheel switches
Main Features
  • AM radio
  • Battery load shed
  • Compass
  • FM radio
  • HD Radio® (if equipped)
  • MyKey®
  • Navigation (if equipped)
  • Satellite radio
  • SIRIUS Travel Link (if equipped)
  • SYNC®
  • SYNC® AppLink™
PremiumAudio9-Speakersw-Touchscreen-2017EdgeSEL.jpg.d892fa49dc2452f42e144226353f8e37.jpg
Bezel Diagnostics - Vehicles With Touchscreen Display - 2017 Edge Workshop Manual.pdf
If the Speaker Walkaround Test does not produce results for any speaker, then have your Edge scanned for Diagnostic Trouble Codes (DTCs), and report back here with any DTCs that were found.
Good luck!
