Haz Posted August 26 Report Share Posted August 26 From the Edge-Nautilus 2.0L EcoBoost Workshop Manual, regarding the P0420 Diagnostic Trouble Code (DTC)... Placing your device cursor over underlined acronyms may yield pop-up full-words descriptions of the acronyms. DTC Fault Trigger Conditions DTC Description Fault Trigger Condition PCM P0420:00 Catalyst System Efficiency Below Threshold Bank 1: No Sub Type Information Sets when PCM detects the bank 1 catalyst system efficiency is below the acceptable threshold. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage capability. As catalyst efficiency deteriorates, its ability to store oxygen declines. Refer to the Catalyst Efficiency Monitor description for additional information. Diagnose any base engine concerns. Refer to the appropriate 303-00 section, Engine System. Possible Causes HO2S 2WD 4WD circuitry concern Exhaust system concern Contaminated oil Base engine concern Fuel injector Turbocharger HO2S 4 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted November 21 Report Share Posted November 21 I have gotten the same recall for my 2018 Edge with a 3.5L V6. Quote Link to comment Share on other sites More sharing options...
Bunky Posted November 22 Report Share Posted November 22 I do not like these kind of recalls in that I would guess engine performance would be reduced. Quote Link to comment Share on other sites More sharing options...
flymore Posted November 23 Report Share Posted November 23 I also got this recall for my 2018 Edge with 3.5L V6. The car just passed emissions test fine, I have no lights or issues and am reluctant to take it in. Quote Link to comment Share on other sites More sharing options...
rafeeki Posted December 7 Report Share Posted December 7 I see no one has yet reported any problems with the recall fix. I got my notice earlier this week, planning on taking it in, in a few days. Hoping for no issues. Ill post my experience Quote Link to comment Share on other sites More sharing options...
MikeInPA Posted December 9 Report Share Posted December 9 (edited) My 2022 Edge just had this recall performed on 12/3. Before the recall, my fuel level was 98% with 343 miles to empty. After the recall, it said 450 miles to empty. Today it's at 64% and 299 miles to go. I'll wait to see what it says after my first fill up. Edited December 9 by MikeInPA mistyped year of car Quote Link to comment Share on other sites More sharing options...
rafeeki Posted December 11 Report Share Posted December 11 I had my recall 24E09 notice taken care of at the dealership yesterday. There is no change in the vehicles performance. As good as before. Rafeek 2 Quote Link to comment Share on other sites More sharing options...
Katy Posted Friday at 01:40 AM Report Share Posted Friday at 01:40 AM I had this recall performed in September. Since then I had issues with my 2022 Ford Edge. First it was the purge valve that needed replacement, then the EGR valve failed (luckily Ford covered it), a week later the car is still stalling and "hickuping". I took it in and now it's the sensor tube to the EGR valve EGR pressure differential inlet tube. Neither Ford nor my extended warranty cover it. The issues started since recall. Either the mechanic made an error or the recall messed up my car. Not sure what to do now. Quote Link to comment Share on other sites More sharing options...
