Emission Recall 24E09 - Certain 2022-2024 Edge and 2022-2023 Nautilus Vehicles - 2.0L EcoBoost
Haz
From the Edge-Nautilus 2.0L EcoBoost Workshop Manual, regarding the P0420 Diagnostic Trouble Code (DTC)...
Placing your device cursor over underlined acronyms may yield pop-up full-words descriptions of the acronyms.
DTC Fault Trigger Conditions
DTC Description Fault Trigger Condition
PCM P0420:00 Catalyst System Efficiency Below Threshold Bank 1: No Sub Type Information Sets when PCM detects the bank 1 catalyst system efficiency is below the acceptable threshold.
Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage capability. As catalyst efficiency deteriorates, its ability to store oxygen declines. Refer to the Catalyst Efficiency Monitor description for additional information.
Diagnose any base engine concerns. Refer to the appropriate 303-00 section, Engine System.
Possible Causes
  • HO2S 2WD 4WD circuitry concern
  • Exhaust system concern
  • Contaminated oil
  • Base engine concern
  • Fuel injector
  • Turbocharger
  • HO2S
  • Like 4
  • 2 months later...
My 2022 Edge just had this recall performed on 12/3.
Before the recall, my fuel level was 98% with 343 miles to empty.
After the recall, it said 450 miles to empty.
Today it's at 64% and 299 miles to go.
I'll wait to see what it says after my first fill up.
Estimated miles until empty is correct now after a couple of tanks of gas. I think it needed to see what my current average MPG was.
Also note that I had the car battery replaced at the same appointment, so maybe that reset the estimated miles to go?
Edited by MikeInPA
mistyped year of car, updated miles until empty estimate
I had this recall performed in September. Since then I had issues with my 2022 Ford Edge. First it was the purge valve that needed replacement, then the EGR valve failed (luckily Ford covered it), a week later the car is still stalling and "hickuping". I took it in and now it's the sensor tube to the EGR valve EGR pressure differential inlet tube. Neither Ford nor my extended warranty cover it. The issues started since recall. Either the mechanic made an error or the recall messed up my car.
Not sure what to do now.
2022 Platinum 2.0l, had this software recall done this past November. I don't drive this vehicle much (wife car) and recently noticed that the one of the dash display selection screens has disappeared, Display Mode for trip, fuel economy, driver assist, settings is gone!! Also notice engine noise from outside vehicle is much louder, sounds to me like a dry turbo squalling. On the plus side, the transmission shifts much better than it had been.
Anybody else notice strange things happen??
  • Sad 1
