Ford Edge 2020 SEL 2.0 Ecoboost making loud engine noises
Deco567
You should still be under warranty. I couldn't hear the attachment, but if you are hearing a loud high frequency ticking noise, it is probably the high pressure injection pump. It sits right on top of the engine, a bit offset to the drivers side and has a small foam cover on it. They can be noisy at times, I dont know why , but they seem to quiet down when warm.
