2019 edge Titanium power liftgate
Mickalo
Hello got a strange problem with our power liftgate. This only happens when parked at our local Walmart. The liftgate opens fine but doesn't want to close with remote button, dash  button or button on liftgate. If hit the button a few times it does finally come down. No where else does happen just at the walmart parking lot. Any suggestion what to check. Also there are no obstruction that would cause the liftgate not to close
TIA
Mike
Edited by Mickalo
Your remote or vehicle is getting jammed by a stronger frequency.
Hackers can hang around crowded parking lots and scrape the owner's
key fob code and spoof it. Once spoofed, they open the door as the
alarms are off. Plug in to the OBDII port, and make a new key fob.
Start the car and.....
Store your key fob in a Faraday shielded fob case. In crowded parking lots,
try to not use the fob to remote lock ( hit twice for that good old "it's locked" feeling)
the doors, lift the hatch etc.
The new breed of car thieves are pretty dang smart!
