supewrench Posted August 11, 2024 Report Share Posted August 11, 2024 I have a 2011 Ford Edge that the brakes are dragging, driving a couple blocks it starts acting up, a lot of parts have been replaced, calipers, rotors, master cylinder, both front brake hoses, brake booster, ABS light is not on, seems like a restriction not releasing the pressure, any suggestions would be helpful Quote Link to comment Share on other sites More sharing options...
garycrist Posted August 11, 2024 Report Share Posted August 11, 2024 How do you know the brakes are dragging? Quote Link to comment Share on other sites More sharing options...
supewrench Posted August 11, 2024 Author Report Share Posted August 11, 2024 after you hit the brakes while driving about a mile I can feel the brakes slowing the car down when i let off the accelerator pedal, plus i can smell the brakes, the car is not being driven due to this problem, just short test drives Quote Link to comment Share on other sites More sharing options...
garycrist Posted August 12, 2024 Report Share Posted August 12, 2024 Have you measured the temps of the rotors? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 23, 2024 Report Share Posted August 23, 2024 (edited) Inasmuch as you have already fired the entire parts cannon, about the only thing left points to the Anti-lock Braking System. If its malfunctioning, it may not set a code, yet still cause the brakes to stick in reverse. The ABS module or its sensors should probably be checked. Possibly drive the car, let the brakes lock then pull the fuse for the abs & see if the brakes release. I know there's no abs codes, but are there any codes stored? Edited August 23, 2024 by enigma-2 Quote Link to comment Share on other sites More sharing options...
