ErinM Posted August 10, 2024 Report Share Posted August 10, 2024 Today as I was sitting at a stop light, I suddenly lost the following: shift in Drive between gears. tire pressure sensor fault speedometer fail odometer fail AC fail air bag light activates RPM, fuel, and temo working fine. Restarted engine, and all sensors responded. Car will still not shift in drive. Reverse, neutral, and park work fine. IS this some kind of master control board failure? Will that impact shifting when in D? Quote Link to comment Share on other sites More sharing options...
