fairlaniac Posted July 30, 2024 Report Share Posted July 30, 2024 Got a P0302 #2 mis-fire code on my '17 2.0 Ecoboost Edge. Installed new Bosch coils and NGK spark plugs. Drove about 125 miles and the code came back. What is the next logical step to diagnose the issue? 91,000 miles. Thanks, Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 30, 2024 Report Share Posted July 30, 2024 I would run some injector cleaner and if there's no improvement do a compression test. Quote Link to comment Share on other sites More sharing options...
fairlaniac Posted July 30, 2024 Author Report Share Posted July 30, 2024 I should add that on start up it seems as though a cylinder is down as it stumbles for about 5 seconds and smooths out. Quote Link to comment Share on other sites More sharing options...
garycrist Posted July 30, 2024 Report Share Posted July 30, 2024 It could be a leaky injector leaking down after it sits. If vacuum accessories, how are the vacuum lines? What did # 3 plug look like as compared to the others? Any coolant loss? If the PCV dumps into the #3 area of the intake mannifold, then it could be carbon on the intake valve/s. If it does it a lot, after shutting down the car for the night, remove the coolant tank cap to relieve the pressure on the system. If that stops the 303 on start-up, then it's head/head gasket/engine time. Gl 73 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 30, 2024 Report Share Posted July 30, 2024 See if the symptoms are similar to this thread: Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 30, 2024 Report Share Posted July 30, 2024 11 hours ago, fairlaniac said: Got a P0302 #2 mis-fire code on my '17 2.0 Ecoboost Edge. Installed new Bosch coils and NGK spark plugs. Drove about 125 miles and the code came back. What is the next logical step to diagnose the issue? 91,000 miles. Thanks, Please add your Model/Year details to your profile signature - Settings - Ford Edge Forum Quote Link to comment Share on other sites More sharing options...
fairlaniac Posted July 30, 2024 Author Report Share Posted July 30, 2024 9 hours ago, garycrist said: It could be a leaky injector leaking down after it sits. If vacuum accessories, how are the vacuum lines? What did # 3 plug look like as compared to the others? Any coolant loss? If the PCV dumps into the #3 area of the intake mannifold, then it could be carbon on the intake valve/s. If it does it a lot, after shutting down the car for the night, remove the coolant tank cap to relieve the pressure on the system. If that stops the 303 on start-up, then it's head/head gasket/engine time. Gl 73 No issue with #3. Actually all looked the same. The only difference was the #2 coil boot had a dark ring on the edge which I attributed to what looked like rust on the spark plug. No burn marks. All looked pretty good. Vacuum lines are fine. I did not have a 303 code. No noticeable coolant loss. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted July 30, 2024 Report Share Posted July 30, 2024 I misread 303 instead of 302. So, I instead mean #2 hole. 1 Quote Link to comment Share on other sites More sharing options...
