Viking daddy Posted July 26, 2024 Report Share Posted July 26, 2024 Changing water pump on 2015 Ford edge sel 3.5 cams are locked in place at Tdc and I can't get the slack out of the old chain to line up on the left cam. I got a new primary chain and I'm having the same problem I desperately need someone who's experienced this and figured it out to reach out to me please the dealership won't help Quote Link to comment Share on other sites More sharing options...
garycrist Posted July 27, 2024 Report Share Posted July 27, 2024 Let me qualify 1st. I have never done one of those but, I've done SOHC as well as DOHC since 1972. If the tensioner is all the way retracted, drop the chain from the bottom sprocket and rotate 1 tooth by hand. If you have to, rotate the engine by hand clock wise to get some slack from the right side to drop the chain. It is best done with the spark plugs removed too! Quote Link to comment Share on other sites More sharing options...
Cerberus Posted July 27, 2024 Report Share Posted July 27, 2024 On 7/26/2024 at 10:31 PM, Viking daddy said: Changing water pump on 2015 Ford edge sel 3.5 cams are locked in place at Tdc and I can't get the slack out of the old chain to line up on the left cam. I got a new primary chain and I'm having the same problem I desperately need someone who's experienced this and figured it out to reach out to me please the dealership won't help Expand many tensioners have a lock out feature that will not let it retract without depressing a little lever. or not retract at all in some cases. retract the tensioner or get a new one if necessary, and use the new chain. Pictures to illustrate the problem help too Quote Link to comment Share on other sites More sharing options...
Viking daddy Posted July 31, 2024 Author Report Share Posted July 31, 2024 The issue was without the tensionor on. The chain stretched. Bought a new primary chain installing everything on top today and hopefully the thing runs right. Cam lockers sat on loose like they should I turned the crank over twice after installation and the marks on the cams lined back up right 1 Quote Link to comment Share on other sites More sharing options...
