After market ambient lights
What year car?
Are you thinking that the lights come on only with the parking lights, or function normally and also with the parking lights and ignition off?
Edited;
Was reading about the kit on Ford Accessories.com.
Set your own mood – and choose your preferred interior LED lighting color – with this Interior Light Kit. It includes a LED-generated light in the cupholder area, and separate light bars for the front wheel wells.
Surprised to learn that the interior light kit also included light bars for the front wheel wells. (My factory lighting doesn't have these.)
Edited by enigma-2
From the WSM:
Ambient Lighting
The ambient lighting subsystem consists of the BCM, and the Light Emitting Diodes (LEDs) located within the floor console, front and rear door
panels, instrument panel and front and rear footwell areas. The ambient lighting is operational when the ignition is in any state other than OFF (the
exception is when it is used in conjunction with the illuminated entry/exit features), the headlamps are on and the outside ambient light level is low.
The BCM provides the voltage to the ambient lighting system, while the touchscreen ( FDIM) is used to cycle through the different color variations
cardiagn.com
or turn the ambient lighting feature on or off. A LIN circuit is routed from the BCM to all of the Light Emitting Diodes (LEDs). There are 3 Light
Emitting Diodes (LEDs) (red, blue and green) housed within each LED assembly. By illuminating various color combinations, the Light Emitting
Diodes (LEDs) are able to produce different colors of ambient light.
The APIM uses software to monitor the user interface from the touchscreen. Based on the ambient lighting system selections made using the
touchscreen, the APIM sends ambient light color request and ambient light intensity request messages over the communication network for color
and brightness settings. The BCM retains the last color and brightness setting between uses.
  • Thanks 1
16 hours ago, Wubster100 said:
For 2021-2024, the only color choice is ice blue.
Just looked at the Ford Accessories Ambient Light Kit and it only fits 09 through 19. So the factory kit doesn't fit.
Wonder if there are there any aftermarket kits that would fit his 2022 SEL?
