BMWR1200c Posted July 20, 2024 Report Share Posted July 20, 2024 For those of you who have done FORScan mods....downloaded the software and license and just ordered the OBDLink EX which should arrive Tuesday. All the videos I've watched say to turn on the ignition without starting the car. But I have keyless ignition/fob in my 2020 SEL. So do I just push the "Start/Stop" button? Will be doing: Bambi foglight mod Extend turn signal to 5 blinks for lane changing Global window up (already does it down) Navigation safety off while driving (if possible) 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 20, 2024 Report Share Posted July 20, 2024 (edited) Just keep your foot off the brake when you push the start/stop button & you'll be able to have the car on, but not running. Edited July 20, 2024 by lildisco 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted July 20, 2024 Report Share Posted July 20, 2024 The IPC will have an orange popup that says something like full accessory power when you turn it on. I would recommend to watch the battery voltage in the bottom right of FORScan and turn the A/C and other accessories off to save power. Quote Link to comment Share on other sites More sharing options...
BMWR1200c Posted July 21, 2024 Author Report Share Posted July 21, 2024 Pleased to say everything I changed using FORScan today works perfectly. Now have: Bambi fog light mod where fog lights stay on simultaneously with high beams; Extended turn signal to 5 blinks from factory setting of 3, for lane changing; Global window up using key fob (already came stock using fob for opening front windows); and Navigation safety off while driving. No more warning when it doesn't sense a passenger in the passenger seat. 1 Quote Link to comment Share on other sites More sharing options...
