Leonard Posted July 15, 2024 Report Share Posted July 15, 2024 I have a 2010 ford edge limited and I’m having problems with the A/C everything works perfectly fine if I pull the relay to the compressor and put a jumper wire in but soon as I pull the jumper wire the compressor and fan stops and air blows hot again I had it at a shop for 3 weeks and they can’t find anything wrong even pulled the dash and went thru all wiring and tested everything could it be a ECM prob? I’m lost and need the A/C working asap thanks Quote Link to comment Share on other sites More sharing options...
