Adding amplifcation to 2024 B&O system?
Normally you install a t harness behind the apim that splits off the factory speaker wires - from the apim to the amp and from the amp back to the speakers.  But you probably have to bypass the B&O amp.  Crutchfield will show you what fits and give you wiring instructions.
I’ve found tons of audio advice including the B&O system upgrades at f150forum.com.  Make sure you get a DSP either separately or built into the amp.  Makes a world of difference.
