Special Service Message 52697 - 2024 Nautilus - "Blind Spot System Fault" And "Cross Traffic System Fault" Displayed In The Message Center With DTC B159C:78 In The SODR
Haz
SSM 52697   2024 Nautilus - "Blind Spot System Fault" And "Cross Traffic System Fault" Displayed In The Message Center With DTC B159C:78 In The SODR
Some 2024 Nautilus vehicles may exhibit "Blind Spot System Fault" and "Cross Traffic System Fault" displayed in the message center with diagnostic trouble code (DTC) B159C:78 stored in the side obstacle detection control module RH (SODR). If this condition occurs, follow Pinpoint Test M in section 419-04B Side and Rear Vision of the Workshop Manual. If diagnosis leads to the removal of the rear bumper cover, inspect the inside of the bumper cover for any labels near the location of the SODR that may be blocking its field view and remove if found. If no labels are found blocking the SODR, continue with normal diagnosis.
