Haz Posted July 2, 2024 Report Share Posted July 2, 2024 (edited) Announcing: Dealer Software Support (DSSH) Hotline for SYNC3 & SYNC4 - Accessory Protocol Interface Module (APIM) Programming Errors Target Dealer Group: All Ford & Lincoln Dealers Target Audience: Dealers, General Managers, Fixed Operations Directors, Service Managers, Parts Managers, Service Advisors, Technicians; Target Dept(s): New Sales, Used Sales, Ford Pro, Finance, Parts, Service, Model e, Warranty, Training; ACTION REQUESTED • Ensure your service teams are aware of the new Dealer Software Support Hotline for SYNC 3 & 4 – Accessory Protocol Interface Module (APIM) Programming errors • To engage, Technicians and vehicles will need to be available to assist with diagnosis • Technicians will be asked to provide a phone number that provides direct access to them to support the Rapid Response SUMMARY Software Diagnosis & Repair Is A Pain Point for our dealers and our customers. Vehicle software related repairs are difficult for dealerships and technicians. Complicating factors include loading software updates, intermittent SYNC issues, and the significant time the technical assistance escalation process can add to repair completion. Ford is committed to improving responsiveness and support for these repairs. DETAILS Program Launch Guidelines Ford will provide a dedicated team to man a Dealer Software Support Hotline (DSSH) that has support from a cross-functional team of Ford experts for software-related concerns. This Hotline is to be used for: • 2023 & 2024 MY vehicles with SYNC-related concerns • DSSH team will provide: • Enhanced rapid response to Technical Support Requests (TSR) related to SYNC diagnosis and repair, with the following goals:. • Initial response to TSR within 15 minutes • Repair direction provided within 4 business hours • Objective to resolve within 2 business days • Module programming support for SYNC modules (APIM) • Repair guidance for replacement of SYNC modules (APIM) Dealer Partner Request The DSSH program will launch with all Ford and Lincoln dealerships. As participating dealership partners: • Ensure normal diagnosis and internal escalation have been completed prior to submitting SYNC-related concerns, using a single point of contact to submit for help via a TSR What Is Changing • SYNC TSRs will be routed directly to the DSSH team for rapid diagnosis and development ofrepair solutions • Requesting technician & vehicle availability to discuss concern • Requesting a phone number with direct access to technician • Access to manually generated Repair Validation Codes (RVCs) will be removed - RVCs will be provided by the DSSH team. Note: Automatic RVCs generated via SYNC Guided Diagnostics remains in place. • SYNC Engineering support is prioritizing diagnosis of complex concerns and prevention of recurrence of systemic issues RESOURCES • SSM 52675 -- SYNC3 - Accessory Protocol Interface Module (APIM) Programming Error... SSM 52675 2019-2024 Various Vehicles - SYNC 3 - Accessory Protocol Interface Module (APIM) Programming Error - "INSTL_ERR12" Using FDRS Or Stuck On "Updating System Software" Or No Response From The Vehicle When Using The Universal USB Updater Some 2019-2024 vehicles equipped with SYNC 3 may experience a programming Error - "INSTL_ERR12" while programming APIM using the Ford Diagnosis and Repair System, or experience a frozen screen which says "updating system software" or no progress/response from module using the universal USB updater. This may be due to low memory in the APIM commonly occurring on software level NU5T-14G381-AB/BB. The current software level can be verified checked in the SYNC tab of PTS, or using the center display screen, Settings > General > About. To correct the condition run the universal USB updater. If unsuccessful, using the latest software version of the Ford Diagnosis and Repair System (FDRS) scan tool, run the service function "APIM - Reset the Accessory Protocol Interface Module Application" and select "Clear All User Data" option. The center display screen will reboot. As soon as module reboot is detected, immediately initiate APIM module programming by inserting the universal USB updater. The APIM Screen should display "successful APIM update" when complete. If process does not complete as expected, retry 1x.If the concern persists, then raise a Technical Support Request for assistance. Do not replace the APIM prior to contacting Technical Support. Edited July 24, 2024 by Haz 3 Quote Link to comment Share on other sites More sharing options...
Haz Posted July 24, 2024 Author Report Share Posted July 24, 2024 (edited) The scope of the Dealer Software Support Hotline is being expanded to responding to 2021 & 2022 and 2023 & 2024 Model Year vehicles with SYNC-related concerns. The Hotline will also serve as a resource to technicians experiencing challenges with Customer Satisfaction Program 24B47. Edited July 24, 2024 by Haz 4 Quote Link to comment Share on other sites More sharing options...
Haz Posted August 8, 2024 Author Report Share Posted August 8, 2024 (edited) The Dealer Software Support Hotline (DSSH) is enforcing the reporting of unique Repair Validation Codes (RVC) to ensure appropriate diagnostics are being conducted before the removal and replacement of certain modules is authorized. With yellow-highlight added, to emphasize text in Edge/Nautilus/MKX columns... Announcing the Dealer Software Support Hotline (DSSH) Update Always use the PTS Diagnostics Tab and Workshop Manual to determine the correct diagnostic for your vehicle concern. Modules in this chart require you to use the following process: If you are required to submit a Technical Support Request (TSR) to the DSSH you must do this prior to module removal. NOTE: This Chart will be updated frequently to keep you informed of policy changes regarding module replacements. Be sure to check here often; a PTS What's New will be released with each updated chart. Edited August 8, 2024 by Haz 3 Quote Link to comment Share on other sites More sharing options...
Bunky Posted August 19, 2024 Report Share Posted August 19, 2024 (edited) I would be curious about dealer feedback on the effectiveness of these issues especially on the 24 Nautilus (what I own). Edited August 19, 2024 by 1004ron Quote Link to comment Share on other sites More sharing options...
Haz Posted August 19, 2024 Author Report Share Posted August 19, 2024 Welcome to the Forum @Bunky! If you've not already reviewed them, clicking on this Search Link will provide a list of posts in this Recalls, TSBs & Warranty forum that may apply to your 2024 Nautilus. If any of these issues are affecting your 2024 Nautilus, you should discuss them with your dealer and -- where any software updates are indicated as resolving the issues -- encourage your dealer to utilize the Dealer Software Support Hotline (DSSH) experts to resolve your 2024 Nautilus' issues. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted August 23, 2024 Author Report Share Posted August 23, 2024 (edited) Dealer Software Support Hotline (DSSH) authorization requirements are being expanded to the ordering of Powertrain Control Modules (PCM) replacements for 2023+ Model Year vehicles... Announcing the Dealer Software Support Hotline (DSSH) Update Always use the PTS Diagnostics Tab and Workshop Manual to determine the correct diagnostic for your vehicle concern. Modules in this chart require a Repair Validation Code (RVC) using the following process: Red – This module requires an RVC obtained through Pinpoint Tests, Guided Routines or provided by the DSSH when module replacement is supported by diagnostics. Yellow - This module requires an RVC obtained through the DSSH when module replacement is supported by diagnostics. Green - This module requires an RVC obtained through Pinpoint Tests, Guided Routines or Manual RVC creation. IMPORTANT: If you are required to submit a Technical Support Request (TSR) to the DSSH you must do this prior to module removal. NOTE: This Chart will be updated frequently to keep you informed of policy changes regarding module replacements. Be sure to check here often; a PTS What's New will be released with each updated chart. Components Requiring a Repair Validation Code (RVC) for Warranty* (updated 09/2024) *Always check the warranty start date to confirm warranty coverage. 2018 Model Year Vehicle Powertrain Control Module (PCM) -12A650- 2018 - All Vehicles under 8,500 GVW YES 2019 Model Year Vehicle Powertrain Control Module (PCM) -12A650- 2019 - All Vehicles under 8,500 GVW YES 2020 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371- / -14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647- / -19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- Body Control Module (BCM) -15604- Electric Brake Booster (EBB) -2005- Steering Effort Control Module (SECM) -3600- Anti-Lock Brake Module (ABS) Hydraulic Control Unit (HCU) 2C219 / 2C215 / 2B373 2C405 / 2C286 / 2B513 Heating, Ventilation and Air Conditioning Module (HVAC) -19980- Front Controls Interface Module (FCIM) -18842- Instrument Panel Cluster (IPC) -10849- Glow Plug Control Module (GPCM) -12B533- 2020 Aviator YES YES YES YES YES YES 2020 Continental YES YES YES YES YES YES YES YES 2020 Corsair YES YES YES YES YES YES YES 2020 EcoSport YES YES YES YES YES 2020 Edge YES YES YES YES YES YES YES YES 2020 Escape YES YES YES YES YES YES YES 2020 Expedition YES YES YES YES YES YES 2020 Explorer YES YES YES YES YES YES YES 2020 F-150 YES YES YES YES YES YES YES YES YES 2020 F-250-600 Super Duty YES YES YES YES YES YES YES YES YES 2020 F-53 Motorhome/F-59 Strip Chassis YES YES 2020 Fusion YES YES YES YES YES YES YES YES 2020 Fusion Hybrid/PHEV YES YES YES YES YES YES YES 2020 MKZ YES YES YES YES YES YES YES YES 2020 MKZ Hybrid YES YES YES YES YES YES YES 2020 Mustang YES YES YES YES YES YES YES YES 2020 Nautilus YES YES YES YES YES YES YES YES 2020 Navigator YES YES YES YES YES YES 2020 Ranger YES YES YES YES YES YES 2020 Transit YES YES YES YES YES YES YES 2020 Transit Connect YES YES YES YES YES YES 2021 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371- / -14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647- / -19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2021 Aviator YES YES YES 2021 Bronco YES YES YES YES 2021 Bronco Sport YES YES YES YES 2021 Corsair YES YES YES 2021 E-350/450 YES YES YES 2021 EcoSport YES YES YES 2021 Edge YES YES YES 2021 Escape YES YES YES 2021 Expedition YES YES YES 2021 Explorer YES YES YES 2021 F-150 YES YES YES YES 2021 F-250-600 Super Duty YES YES YES 2021 F-53 Motorhome/F-59 Strip Chassis YES 2021 F-650/750 YES YES YES 2021 Mustang YES YES YES 2021 Mustang Mach-E YES YES YES YES 2021 Nautilus YES YES YES 2021 Navigator YES YES YES 2021 Ranger YES YES YES 2021 Transit YES YES YES YES 2021 Transit Connect YES YES YES 2022 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371- / -14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647- / -19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2022 Aviator YES YES YES YES YES 2022 Bronco YES YES YES YES YES YES 2022 Bronco Sport YES YES YES YES YES YES 2022 Corsair YES YES YES YES YES 2022 E-350/450 YES YES YES YES 2022 EcoSport YES YES YES 2022 Edge YES YES YES YES YES 2022 Escape YES YES YES YES YES 2022 Expedition YES YES YES YES 2022 Explorer YES YES YES YES YES 2022 F-150 YES YES YES YES YES 2022 F-250-600 Super Duty YES YES YES YES YES 2022 F-53 Motorhome/F-59 Strip Chassis YES YES 2022 F-650/750 YES YES YES YES 2022 Maverick YES YES YES YES YES 2022 Mustang YES YES YES YES 2022 Mustang Mach-E YES YES YES YES YES 2022 Nautilus YES YES YES YES YES 2022 Navigator YES YES YES YES 2022 Ranger YES YES YES YES 2022 Transit YES YES YES YES YES YES 2022 Transit Connect YES YES YES YES 2023 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371- / -14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647- / -19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2023 Aviator YES YES YES YES YES 2023 Bronco YES YES YES YES YES YES 2023 Bronco Sport YES YES YES YES YES YES 2023 Corsair YES YES YES YES 2023 E-350/450 YES YES YES YES 2023 Edge YES YES YES YES YES 2023 Escape YES YES YES YES 2023 Expedition YES YES YES YES 2023 Explorer YES YES YES YES YES 2023 F-150 YES YES YES YES YES 2023 F-250-600 Super Duty YES YES YES YES YES 2023 F-53 Motorhome/F-59 Strip Chassis YES YES 2023 F-650/750 YES YES YES YES 2023 Maverick YES YES YES YES YES 2023 Mustang YES YES YES YES 2023 Mustang Mach-E YES YES YES YES YES 2023 Nautilus YES YES YES YES YES 2023 Navigator YES YES YES YES 2023 Ranger YES YES YES YES 2023 Transit YES YES YES YES YES YES 2023 Transit Connect YES YES YES YES 2024 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371- / -14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647- / -19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2024 Aviator YES YES YES YES YES 2024 Bronco YES YES YES YES YES YES 2024 Bronco Sport YES YES YES YES YES YES 2024 Corsair YES YES YES YES 2024 E-350/450 YES YES YES YES 2024 Edge YES YES YES YES YES 2024 Escape YES YES YES YES 2024 Expedition YES YES YES YES 2024 Explorer YES YES YES YES YES 2024 F-150 YES YES YES YES YES 2024 F-250-600 Super Duty YES YES YES YES YES 2024 F-53 Motorhome/F-59 Strip Chassis YES YES 2024 F-650/750 YES YES YES YES 2024 Maverick YES YES YES YES YES 2024 Mustang YES YES YES YES 2024 Mustang Mach-E YES YES YES YES YES 2024 Nautilus YES YES YES YES 2024 Navigator YES YES YES YES 2024 Ranger YES YES YES YES 2024 Transit YES YES YES YES YES YES 2025 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371- / -14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647- / -19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2025 Aviator YES YES YES YES 2025 Bronco YES YES YES YES YES YES 2025 Bronco Sport YES YES YES YES YES 2025 Corsair YES YES YES YES 2025 E-350/450 YES YES YES 2025 Escape YES YES YES YES 2025 Expedition YES YES YES YES 2025 Explorer YES YES YES YES 2025 F-150 YES YES YES YES YES 2025 F-250-600 Super Duty YES YES YES YES YES 2025 F-53 Motorhome/F-59 Strip Chassis YES 2025 F-650/750 YES YES YES 2025 Maverick YES YES YES YES YES 2025 Mustang YES YES YES YES 2025 Mustang Mach-E YES YES YES YES YES 2025 Navigator YES YES YES YES 2025 Ranger YES YES YES YES 2025 Transit YES YES YES YES YES Edited August 23, 2024 by Haz 3 Quote Link to comment Share on other sites More sharing options...
Bunky Posted August 24, 2024 Report Share Posted August 24, 2024 I am sure all these notices and requirements complicate a service manager's life. Quote Link to comment Share on other sites More sharing options...
Haz Posted September 23, 2024 Author Report Share Posted September 23, 2024 (edited) DSSH Is Expanding To Add GWM And TCU - Ford Professional Technician System (PTS) "What's New" message - September 20, 2024 The Dealer Support Software Hotline (DSSH) is expanding to include 2023 and later Gateway Module (GWM) and 2023 and later Telematic Control Unit (TCU) for USA dealers only on September 23, 2024. The GWM and TCU modules will now require a repair validation code (RVC) to order, codes will be provided by the DSSH team when module replacement is supported. GWM and TCU part number will be set with K Codes and dealerships will need to call 1-800-842-2474 to place an order and provide P&A code, VIN, RVC code, and part number. Connected vehicles service concerns will now be supported as well through the DSSH process. Announcing the Dealer Software Support Hotline (DSSH) Update Always use the PTS Diagnostics Tab and Workshop Manual to determine the correct diagnostic for your vehicle concern. Modules in this chart require a Repair Validation Code (RVC) using the following process: Red – This module requires an RVC obtained through Pinpoint Tests, Guided Routines or provided by the DSSH when module replacement is supported by diagnostics. Yellow - This module requires an RVC obtained through the DSSH when module replacement is supported by diagnostics. Green - This module requires an RVC obtained through Pinpoint Tests, Guided Routines or Manual RVC creation. IMPORTANT: If you are required to submit a Technical Support Request (TSR) to the DSSH you must do this prior to module removal. Components Requiring a Repair Validation Code (RVC) for Warranty* (updated 09/2024) *This chart is a general guideline. Specific vehicle coverage must be confirmed using warranty start date or mileage and country or state regulations. These warranty-related charts do not include Ford or Lincoln Protect RVC requirements. Ford or Lincoln Protect extended warranty policies generally require an RVC when provided by the guided routines. 2018 Model Year Vehicle Powertrain Control Module (PCM) -12A650- 2018 C-MAX Hybrid Green 2018 Continental Green 2018 E-350/450 2018 EcoSport Green 2018 Edge Green 2018 Escape Green 2018 Expedition Green 2018 Explorer Green 2018 F-250-550 Super Duty 2018 F-53 Motorhome/F-59 Strip Chassis 2018 Fiesta Green 2018 Flex Green 2018 Focus Green 2018 Focus RS Green 2018 Fusion Green 2018 MKC Green 2018 MKT Green 2018 MKX Green 2018 MKZ Green 2018 Mustang Green 2018 Navigator Green 2018 Taurus Green 2018 Transit Green 2018 Transit Connect Green 2019 Model Year Vehicle Powertrain Control Module (PCM) -12A650- 2019 Continental Green 2019 E-350/450 Green 2019 EcoSport Green 2019 Edge Green 2019 Escape Green 2019 Expedition Green 2019 Explorer Green 2019 F-150 Green 2019 F-250-550 Super Duty Green 2019 F-53 Motorhome/F-59 Strip Chassis Green 2019 Fiesta Green 2019 Flex Green 2019 Fusion Green 2019 MKC Green 2019 MKT Green 2019 MKZ Green 2019 Mustang Green 2019 Nautilus Green 2019 Navigator Green 2019 Ranger Green 2019 Taurus Green 2019 Transit Green 2019 Transit Connect Green 2020 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371 / 14G670- Display Screen Equipped with SYNC -10D885- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- Body Control Module (BCM) -15604- Electric Brake Booster (EBB) -2005- Steering Effort Control Module (SECM) -3600- Anti-Lock Brake Module (ABS) Hydraulic Control Unit (HCU) 2C219 / 2C215 / 2B373 2C405 / 2C286 / 2B513 Heating, Ventilation and Air Conditioning Module (HVAC) -19980- Front Controls Interface Module (FCIM) -18842- Instrument Panel Cluster (IPC) -10849- Glow Plug Control Module (GPCM) -12B533- 2020 Aviator Green Green Green Green Green Green 2020 Continental Green Green Green Green Green Green Green Green 2020 Corsair Green Green Green Green Green Green Green 2020 EcoSport Green Green Green Green Green 2020 Edge Green Green Green Green Green Green Green Green 2020 Escape Green Green Green Green Green Green Green 2020 Expedition Green Green Green Green Green Green 2020 Explorer Green Green Green Green Green Green Green 2020 F-150 Green Green Green Green Green Green Green Green Green 2020 F-250-600 Super Duty Green Green Green Green Green Green Green Green Green 2020 F-53 Motorhome/F-59 Strip Chassis Green Green 2020 Fusion Green Green Green Green Green Green Green Green 2020 MKZ Green Green Green Green Green Green Green Green 2020 Mustang Green Green Green Green Green Green Green Green 2020 Nautilus Green Green Green Green Green Green Green Green 2020 Navigator Green Green Green Green Green Green 2020 Ranger Green Green Green Green Green Green 2020 Transit Green Green Green Green Green Green Green 2020 Transit Connect Green Green Green Green Green Green 2021 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371 / 14G670- Display Screen Equipped with SYNC -10D885- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2021 Aviator Red Green Green 2021 Bronco Red Green Green Green 2021 Bronco Sport Red Green Green Green 2021 Corsair Red Green Green 2021 E-350/450 Red Green Green 2021 EcoSport Red Green Green 2021 Edge Red Green Green 2021 Escape Red Green Green 2021 Expedition Red Green Green 2021 Explorer Red Green Green 2021 F-150 Red Green Green Green 2021 F-250-600 Super Duty Red Green Green 2021 F-53 Motorhome/F-59 Strip Chassis Green 2021 F-650/750 Red Green Green 2021 Mustang Red Green Green 2021 Mustang Mach-E Red Green Green Green 2021 Nautilus Red Green Green 2021 Navigator Red Green Green 2021 Ranger Red Green Green 2021 Transit Red Green Green Green 2021 Transit Connect Red Green Green 2022 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371 / 14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647 / 19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- 2022 Aviator Red Green Yellow Yellow Green 2022 Bronco Red Green Yellow Yellow Green Green 2022 Bronco Sport Red Green Yellow Yellow Green Green 2022 Corsair Red Green Yellow Yellow Green 2022 E-350/450 Red Green Yellow Green 2022 EcoSport Red Green Green 2022 Edge Red Green Yellow Yellow Green 2022 Escape Red Green Yellow Yellow Green 2022 Expedition Red Green Yellow Green 2022 Explorer Red Green Yellow Yellow Green 2022 F-150 Red Green Yellow Green Green 2022 F-250-600 Super Duty Red Green Yellow Yellow Green 2022 F-53 Motorhome/F-59 Strip Chassis Yellow Green 2022 F-650/750 Red Green Yellow Green 2022 Maverick Red Green Yellow Green Green 2022 Mustang Red Green Yellow Green 2022 Mustang Mach-E Red Green Yellow Green Green 2022 Nautilus Red Green Yellow Yellow Green 2022 Navigator Red Green Yellow Green 2022 Ranger Red Green Yellow Green 2022 Transit Red Green Yellow Yellow Green Green 2022 Transit Connect Red Green Yellow Green 2023 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371 / 14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647 / 19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- Body Control Module (BCM) -15604- Gateway Module (GWM) -14G650 / 14H474- Telematics Control Unit (TCU) 14H074 / 14H076 / 14H316 2023 Aviator Red Green Yellow Yellow Red Yellow Yellow Yellow 2023 Bronco Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2023 Bronco Sport Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2023 Corsair Red Green Yellow Red Yellow Yellow Yellow 2023 E-350/450 Red Green Yellow Red Yellow Yellow Yellow 2023 Edge Red Green Yellow Yellow Red Yellow Yellow Yellow 2023 Escape Red Green Yellow Red Yellow Yellow Yellow 2023 Expedition Red Green Yellow Red Yellow Yellow Yellow 2023 Explorer Red Green Yellow Yellow Red Yellow Yellow Yellow 2023 F-150 Red Green Yellow Red Green Yellow Yellow Yellow 2023 F-250-600 Super Duty Red Green Yellow Red Green Yellow Yellow Yellow 2023 F-53 Motorhome/F-59 Strip Chassis Yellow Red Yellow Yellow Yellow 2023 F-650/750 Red Green Yellow Red Yellow Yellow Yellow 2023 Maverick Red Green Yellow Red Green Yellow Yellow Yellow 2023 Mustang Red Green Yellow Red Yellow Yellow Yellow 2023 Mustang Mach-E Red Green Yellow Red Green Yellow Yellow Yellow 2023 Nautilus Red Green Yellow Yellow Red Yellow Yellow Yellow 2023 Navigator Red Green Yellow Red Yellow Yellow Yellow 2023 Ranger Red Green Yellow Red Yellow Yellow Yellow 2023 Transit Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2023 Transit Connect Red Green Yellow Red Yellow Yellow Yellow 2024 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371 / 14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647 / 19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- Body Control Module (BCM) -15604- Gateway Module (GWM) -14G650 / 14H474- Telematics Control Unit (TCU) 14H074 / 14H076 / 14H316 2024 Aviator Red Green Yellow Yellow Red Yellow Yellow Yellow 2024 Bronco Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2024 Bronco Sport Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2024 Corsair Red Green Yellow Red Yellow Yellow Yellow 2024 E-350/450 Red Green Yellow Red Yellow Yellow Yellow 2024 Edge Red Green Yellow Yellow Red Yellow Yellow Yellow 2024 Escape Red Green Yellow Red Yellow Yellow Yellow 2024 Expedition Red Green Yellow Red Yellow Yellow Yellow 2024 Explorer Red Green Yellow Yellow Red Yellow Yellow Yellow 2024 F-150 Red Green Yellow Red Green Yellow Yellow Yellow 2024 F-250-600 Super Duty Red Green Yellow Red Green Yellow Yellow Yellow 2024 F-53 Motorhome/F-59 Strip Chassis Yellow Red Yellow Yellow Yellow 2024 F-650/750 Red Green Yellow Red Yellow Yellow Yellow 2024 Maverick Red Green Yellow Red Green Yellow Yellow Yellow 2024 Mustang Red Green Yellow Red Yellow Yellow Yellow 2024 Mustang Mach-E Red Green Yellow Red Green Yellow Yellow Yellow 2024 Nautilus Red Green Yellow Red Yellow Yellow Yellow 2024 Navigator Red Green Yellow Red Yellow Yellow Yellow 2024 Ranger Red Green Yellow Red Yellow Yellow Yellow 2024 Transit Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2025 Model Year Vehicle SYNC Accessory Protocol Interface Module (APIM) -14G371 / 14G670- Display Screen Equipped with SYNC -10D885- Image Processing Module A (IPMA) -14G647 / 19H406- Image Processing Module B (IPMB) -19H405- Powertrain Control Module (PCM) -12A650- Power Steering Control Module (PSCM) -3504- Body Control Module (BCM) -15604- Gateway Module (GWM) -14G650 / 14H474- Telematics Control Unit (TCU) 14H074 / 14H076 / 14H316 2025 Aviator Red Green Yellow Red Yellow Yellow Yellow 2025 Bronco Red Green Yellow Yellow Red Green Yellow Yellow Yellow 2025 Bronco Sport Red Green Yellow Red Green Yellow Yellow Yellow 2025 Corsair Red Green Yellow Red Yellow Yellow Yellow 2025 E-350/450 Red Green Red Yellow Yellow Yellow 2025 Escape Red Green Yellow Red Yellow Yellow Yellow 2025 Expedition Red Green Yellow Red Yellow Yellow Yellow 2025 Explorer Red Green Yellow Red Yellow Yellow Yellow 2025 F-150 Red Green Yellow Red Green Yellow Yellow Yellow 2025 F-250-600 Super Duty Red Green Yellow Red Green Yellow Yellow Yellow 2025 F-53 Motorhome/F-59 Strip Chassis Red Yellow Yellow Yellow 2025 F-650/750 Red Green Red Yellow Yellow Yellow 2025 Maverick Red Green Yellow Red Green Yellow Yellow Yellow 2025 Mustang Red Green Yellow Red Yellow Yellow Yellow 2025 Mustang Mach-E Red Green Yellow Red Green Yellow Yellow Yellow 2025 Navigator Red Green Yellow Red Yellow Yellow Yellow 2025 Ranger Red Green Yellow Red Yellow Yellow Yellow 2025 Transit Red Green Yellow Red Green Yellow Yellow Yellow Edited September 23, 2024 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Bunky Posted September 23, 2024 Report Share Posted September 23, 2024 (edited) All signs that Ford is trying to manage warranty costs. For us Lincoln Nauti owners, a software update would likely reduce warranty costs while mechanics try to debug software issues. Edited September 23, 2024 by Bunky Quote Link to comment Share on other sites More sharing options...
