TSB 24-2199 - 2024 Edge 2.0L EcoBoost AWD - Various Driveability Symptoms And/Or Illuminated MIL With Evaporative Emissions DTCs After A Refuel Event
Haz
TECHNICAL SERVICE BULLETIN
2.0L - AWD - Various Driveability Symptoms And/Or Illuminated MIL With Evaporative Emissions DTCs After A Refuel Event
24-2199
01 July 2024
Model:
Ford
2024 Edge
Engine: 2.0L EcoBoost
AWD
Markets: North American markets only
Issue: Some 2024 Edge vehicles equipped with a 2.0L engine and AWD may experience the fuel tank not filling up beyond half-full, hard to start, and/or stalls upon restart after refueling. A MIL with DTC P04F0, P0451, P0455, and/or P0496 may also be stored in the PCM. This may be due to a disconnected fuel vapor line inside the fuel tank. To correct the condition, follow the Service Procedure to reattach the fuel tank vapor line inside the fuel tank.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2024 Edge
• 2.0L
 AWD
• At least one of the following symptoms:
- Fuel tank not filling up beyond half-full
- Hard to start
- Stalls upon restart after refueling
Parts
Service Part Number Claim Quantity Package Order Quantity Number in Package Description
W714265-S442 2 1 4 Exhaust Nut
CV6Z-9450-E 1 1 1 Exhaust Gasket
F2GZ-4682-A 3 3 1 Driveshaft To PTU Bolts/Straps
W790063-S900 3 1 3 Driveshaft To Pinion Bolts/Straps
W712154-S439 2 1 4 Center Bearing Bolts
4L3Z-9276-AA 1 1 1 Fuel Pump And Sender Unit Ring
CCPZ-3B477-B 2 2 1 Axle Nut
K2GZ-9D653-A 1 1 1 Evaporative Emissions Canister
W718188-S439 8 2 4 Wheel Bearing And Hub Retainers
W715448-S439 2 1 4 Halfshaft Retaining Clip
W715624-S439 4 1 4 Caliper Bracket Support Bolt
XY-75W-QL As Needed As Needed   Motorcraft® Differential Rear Drive Unit Fluid
PM-4-A As Needed As Needed   Motorcraft® Metal Brake Parts Cleaner (Compliant With Low Volatile Organic Compound Requirements As Required In Some USA States)
PM-4-B As Needed As Needed   Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Volatile Organic Compound Requirements)
Claim Quantity refers to the total number of individual pieces required to repair the vehicle.
Package Order Quantity refers to the amount of the service part number package(s) required to repair the vehicle.
Number In Package refers to the number of individual pieces included in a service part number package.
As Needed indicates the part is necessary but amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Service Part New Vehicle (SPNV)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SPNV/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2024 Edge AWD 2.0L EcoBoost: Inspect And Connect Vapor Hose Includes Time To Replace EVAP Canister And Remove And Install Fuel Pump Sender (Do Not Use With Any Other Labor Operations) 242199A 4.9 Hrs.
Repair/Claim Coding
Causal Part: 9002
Condition Code: 01
Service Procedure
1. Remove the fuel tank assembly. Refer to the WSM, Section 310-01A, Removal and Installation, Fuel Tank.
2. Remove fuel pump and sender unit. Refer to the WSM, Section 310-10A, Removal and Installation, Fuel Pump and Sender.
3. Inspect the inside of the fuel tank for a disconnected fuel vapor hose. (Figures 1-2)
Figure 1
Figure 2
4. Is the hose disconnected?
(1). Yes - reattach the hose. Proceed to Step 5.
NOTE: Do not reinstall the fuel tank until the EVAP canister has been replaced.
(2). No - reassemble vehicle and refer to the WSM for normal diagnostics outside of this article. Repair is complete.
5. Replace the EVAP canister. Refer to WSM, Section 303-13A, Removal and Installation, Evaporative Emission Canister.
© 2024 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
TSB 24-2199 and referred-to Workshop Manual sections are attached below as PDF documents...
TSB 24-2199 - 2.0L EcoBoost - AWD - Various Driveability Symptoms And-Or Illuminated MIL With Evap Emissions DTCs After A Refuel Event.pdf Fuel Tank - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Fuel Pump and Sender Unit - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Evaporative Emission Canister - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf
Edited by Haz
  • Haz changed the title to TSB 24-2199 - 2024 Edge 2.0L EcoBoost AWD - Various Driveability Symptoms And/Or Illuminated MIL With Evaporative Emissions DTCs After A Refuel Event
