Terrible Tim Posted July 1, 2024 Report Share Posted July 1, 2024 I have replaced the (expletive deleted) flakey HID headlight bulbs with LEDs. Now, the left front parking light is out. Is there a separate fuse or relay for the left and right sides? My somewhat educated guess would be that they are. However, I cannot find a fuse diagram for the models with the HID. Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
Haz Posted July 2, 2024 Report Share Posted July 2, 2024 Welcome to the Forum, @Terrible Tim! Relevant sections from the 2011 Edge Workshop Manual and Wiring Resource are attached below as PDF documents... If your diagnostic efforts progress to you requiring electrical connector information, I can supply that as well. Good luck! Front Park-Turn Lamps - Wiring Diagram - 2011 Edge.pdf Park-Turn Lamps, Left Hand - Fuse F14 - Wiring Diagram - 2011 Edge.pdf Park-Turn Lamps, Right Hand - Fuse F13 - Wiring Diagram - 2011 Edge.pdf Body Control Module (BCM) - Fuse Location Diagram - 2011 Edge.pdf Body Control Module (BCM) - Fuse-Circuits Listing - 2011 Edge.pdf Turn Signal and Hazard Lamps - Diagnosis and Testing - 2011 Edge.pdf Parking, Rear and License Plate Lamps - Diagnosis and Testing - 2011 Edge.pdf HID Headlamps - Wiring Diagram - 2011 Edge.pdf Adaptive Headlamps - Wiring Diagram - 2011 Edge.pdf Headlamps - Diagnosis and Testing - 2011 Edge.pdf 1 Quote Link to comment Share on other sites More sharing options...
