Diego2014Edge Posted July 1 Report Share Posted July 1 Hello everyone, Anyone know if the 2014 Edge headlight has a vent hole? Recently developed a condensation issue in one headlight only. Can't seem to make it go away. Quote Link to comment Share on other sites More sharing options...
08edge75231 Posted July 5 Report Share Posted July 5 Find a small drill 1/8 or so drill in the bottom to let the mostre out or change the whole headlight 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 25 Report Share Posted July 25 On 7/1/2024 at 1:08 PM, Diego2014Edge said: Hello everyone, Anyone know if the 2014 Edge headlight has a vent hole? Recently developed a condensation issue in one headlight only. Can't seem to make it go away. There is a "rectangle" right above/next to the main headlight cover, which is a one-way vent. Supposed to let the moist air out (think of moisture as a pressure) but prevent air from entering. Usually driving with your headlights on will produce enough heat to dry out the fixture. Others that have had similar problems, replaced this vent and used a hairdryer to dry out the interior. Another possibly is the seal around the two halves of the headlight has cracked and is letting moist air in. Fix is to run a bead of clean sealant over the joint that connects the two haves. Quote Link to comment Share on other sites More sharing options...
