rkedz Posted March 6, 2009 Report Share Posted March 6, 2009 I just purchased a 2007 edge sel awd. Is it supposed to have a temp digital reading with the directional compass and odometer? I don't see it. Thx Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted March 6, 2009 Report Share Posted March 6, 2009 I just purchased a 2007 edge sel awd. Is it supposed to have a temp digital reading with the directional compass and odometer? I don't see it.Thx Hi rkedz. :D If you have the EATC (Automatic Temperature Control) HVAC system, the temperature will be shown in the EATC system display, not the Information center display. You press the button that is marked "EXT" to get the external temperature reading. Press it again to return to the inside temperature. It can display one or the other. For those with the Manual HVAC system, there is no external temperature display. This information (and a lot more) is also explained in detail in the Owners Manual. If you purchased used and did not get an Owners Manual, you can download a PDF version here: LINK: Owners Guides Fill in the drop down boxes with your vehicle information, then click "submit". Then click on "Edge Owner Guide". As you will see, you can also download the Warranty and Maintenance Guides. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
