FWD to larger AWD rotors
At around 87,000 miles on my 2019 FWD SEL, and the rear pads are getting pretty thin. I have not had a car in recent memory that I didn't do some sort of big brake upgrade to (10.8 inch to 13 inch Cobra on my Mark VIII, 14 inch GT500 on my Grand Marquis, etc).
Mine is FWD and has the smaller front rotors (316mm), and I want to go with the 345mm AWD ones (not looking to go with the ST Base or PP). I will leave the rears the standard 316mm solid.
It seems like the caliper is the same for either rotor (and pads), just the bracket/support/mount is different. Can I just go with new caliper mounts, rotors, and pads from the AWD? Or do I need the bracket and caliper? If I put in the VIN for my FWD and for an AWD vehicle, I get same PN for calipers, different for rotors and brackets(supports), so not sure. Also they are referenced as "front vented 17" and 18 front vented. I assume that is for older years that still had 17 inch wheels standard (but all 2015+ have 18+ wheels).
If I can get away with not unhooking the calipers so I need to bleed them, all the better. I am going to guess that it won't affect anything like ABS, stop and go cruise, collision avoidance, etc. I have a 17 inch spare, I think I have seen recent posts about 17 inch spare fitting over front and rear ST brakes, which have same rotor size but caliper is different.
  • 5 months later...
So this will finally happen! I am still waiting for the front caliper brackets to match the larger rotors, but Saturday is the day I hope! These front rotors are beefy. It is a daily driver for my wife, and it also gets about 20,000 miles a year, so I didn't go with drilled and slotted, or aggressive pads. I do drive it from time to time so I will appreciate the larger front brakes I hope. I don't really need the coated rotors either, I live in the desert and rust is not really an issue, but for the cost difference, I went with them. I do have pretty good luck with Power Stop brake parts, so I hope that continues.
$453 after shipping, $388 after $65 rebate. It is actually cheaper than the above screen shot since they have the same components in a kit, and I added slide pins and boots, and still cheaper. Shipping was $53 because it came from 2 different places, that 5% off discount of $20 didn't cover the shipping like it usually does. Still $100 cheaper than I can get it locally, with the $35 in shipping for the rotors (the shipping for the brackets is $15).
The 2 sizes of Hex key/sockets that no set ever has? 7mm and 11mm, so got those:
The FedEx guy hates me, 160 pounds of boxes!
Why 160 pounds? Well, doing the brakes on my daughters 2015 Fusion as well, at 105,000 miles the rear pads are at 2mm, fronts have enough, but she does a lot of mountain pass driving and cooks them. A little meat on the pads will help with that a bit. I also had to do the normal RockAuto shuffle of adding and removing stuff to get the shipping costs down. It was actually cheaper to order the transmission fluid and air and cabin filters, it knocked $45 off the cost of shipping (adding $38 in parts that will be used, not just tossed in randomly). So her brakes all around will be $200 after rebate. She got quoted $550 for the rear only.
  • Thanks 1
I forgot to wait for the 18 inch spare to arrive, but if I have a flat on the front the next 2 days, I will put the spare on the back (which I would likely do with a FWD vehicle anyways). Work is done, 5 hours, because I have no power tools, no lift, and ADHD so I scrubbed and details the back of the rims, the suspension, the brakes, the chassis, etc. It was the little things that kicked my butt. Replacing the rear caliper boots and slides, with the lower having the hard plastic, was a PITA.
I didn't pay enough attention to the FWD being rear vented, and AWD being front vented. I didn't change the brake backing pad.
The magic that makes it happen, left is the FWD caliper bracket, right is the AWD bracket:
The different rotors:
There was way more rust than I am used to, with a CA and AZ car. but still pretty easy to work on.
The money shot:
No chance the 17 inch spare will fit
The real reason I dug into the brakes. Rear had 2-3mm left. It was starting to shake on normal braking, not just emergency or heavy braking coming down a mountain pass.
Fronts has a ton of life left, but I couldn't see just doing the rear, and I wanted the larger brakes
So far just drove it enough to sorta bed in the brakes. These are already burnt in (they smelled like I rode them down a mountain pass, still in the box), I didn't do any emergency braking, I did test out adaptive cruise but not the stop part of it.
Just staring to wear through the coating
A tool I used on a 2000 Ford Expedition, where the rotor hat is the same exact size as the hub, and the rust weld themselves together. Why beat the crap out of something when you can use leverage. This temporary tool had been used on quite a few rusted on rotors and works like a champ. As a temporary one use tool I didn't do enough to it, I need to get rid of the first 3 or 4 rows of threads because the end gets boogered up, but easy enough to clean up.
  • Like 3
You just answered a prayer of mine for bigger brakes.  I may be rebudgeting according to what's here (including the 7mm and 11 mm sockets).
But before I plunk down the coin, can you let me know if the braking performance has improved over the stock FWD rotors? With me considering an upgrade to 20s and the bad drivers around here, bigger brakes might be a very good investment.
BTW, I am looking at the PowerStop pads as well.
Edited by PrinzII
They are much better than the partially worn 96,000 miles ones that they replaced. The little shimmy I was getting before is gone. The slight noise is gone.
I haven't really had a chance to emergency type stop test them. I did some moderate braking and sitting in park to not leave hot spots on the rotors, and I tested adaptive cruise but not stop and go cruise. I feel that they are better than the smaller ones. I don't like in a mountainous region but that is where the original ones were taxed. 1 fairly heavy braking session caused them to violently shake next time they got used. I learned from my mistake and use Sport mode and more gap, and stopped using adaptive cruise, as it really does heavy braking when needed.
If I was really going for improved brakes for heavier use situations, and not for daily driving with occasional heavy braking, if it wasn't my wife's daily driver, but my daily or weekend driver, I would have done ST calipers and slotted and drilled rotors and pads that need warmed up to work. But I get about 40,000 miles out of pads on those, and after 60k the rotors need replaced. Averaging 25,000 miles a year on the daily driver I don't want to do brakes every 1.5 years.
Well worth the update with a normal brake change. Could the fronts have gone another 60k miles? Yes! They were starting to fade as mentioned, and not doing well with excessive braking (which my other vehicle with more aggressive setup handles just fine). I don't think it was the rears only causing the issues. I wouldn't take 20k brakes off and do this.
Expand
I have some areas that could really work that combo out.  I am in a fairly mountainous state and that would be a good investment for going downhill on some roads.
Since yours is a 2019, you could do the ST calipers easily.  Mine is a 2018.  Will those calipers even fit?
Expand
The ST caliper brackets are hard(er) to find except at the dealer. I Priced it all out and I just wasn't sold on the cost vs gain. Just the standard ST vs the Performance Brake package brakes.
I haven't tried, but I don't see why you couldn't do that on a 2018, the ST front caliper, rotors, or even the rear larger and vented rotors and calipers. The front ST calipers have 4mm larger pistons (x2 for each caliper), I doubt it is enough to require any other changes like master cylinder with more capacity, but I don't know.
The rotors I got are inverted hat rotors like the standard ST brakes have, and the Performance Package ones are conventional (like my smaller original rotors). I used the tech specs document, VINs for AWD, ST, ST w/perf brakes I found on vehicles for sale, and parts.ford.com to come up with my plan and parts list (things like the same caliper and pads for both sized rotors, for example). I couldn't find a good tech spec document for 2018 (only found 2015, with less info than 2019).
2019 Edge Tech Specs.pdfFetching info...
Got the larger (18) spare. I was searching for an aluminum one, but apparently sellers think they are worth $300+. Also just trying to find one for an Edge they were more expensive, and/or the seller was vague on if it would include the tire or not (most had similar text about "tire not included (with full sized tire)") so I didn't want to chance that.
Scored one out of an MKX (2017), with the 4 holes in it. Since the tire has the same aspect ratio as the 17, it is taller. The tire is more square (I am used to the rounded profile tread surface). The wheel had never been mounted, and the tire never driven on. I was worried that maybe the surround was different, and it wouldn't fit, but it fits just about as well as the smaller one, it isn't easy to get it out as the back is under the plastic trim, so you need to get the front up and lifted up.
Different in diameter:
In place, under the cargo floor, with all my accumulated emergency, spare, and handy to have stuff.
I got the chance to do some heavy braking with it, and no fade or chattering at all. Compared to the worn stuff, I am sure just being new is most of that, but still I think a worthwhile small upgrade, staying with stock available stuff. The wear pattern on the discs looks good (under the coating there is the crosshatching, and only in small section is it wearing beyond the cross hatch so far, and one small section that still has some of the coating.
Next up, painting the calipers red, as the wheels are open enough to make it worth it. Maybe some other color, as they are easier to keep clean painted versus raw. And as all my vehicles, the passenger side were dirtier, since there is much more debris on the road on that side (same with inside of the rim, and chips in paint, etc).
  On 12/15/2024 at 7:31 PM, 1004ron said:
Is there any change required to the front/rear proportioning valves when changing the rotor specs?
I ask because on one of my vehicles the manufacturer brought out a recall/campaign upgrade to the front rotors and callipers and included was two new proportioning valves.
Expand
That was one obstacle I wasn't willing to confront going to the ST calipers. Since they are larger pistons, I could see there being more required changes. There are different part numbers for the brake boosters FWD vs AWD, so there might be more to what I did than I expected. I couldn't find a Ford parts master cylinder part number for my FWD small rotor vehicle, just for the ST.
I also have let the Adaptive Cruise do it's thing in stop and go traffic, as well as interstate 70-30 mph traffic flow, and it does fine, whoa'ed down as expected in all situations.
  • 3 months later...
Just a 100 day update (only at 101,500 miles, only 5k miles on new brakes, it was down for the transmission for too long).
Got the $65 rebate check ($130 since I did 2 kits), with a check that is good until 4/11/2025 (so less than a month, hah, I digitally deposited it already).
My normal driving environment is pretty flat, but so far no issues in normal driving (even near emergency stops), using Adaptive Cruise with Stop and Go also. Maybe it will creep once more when the car in front is stopped, but I think it always did this, making me wonder if it would stop creeping.
Went to the mountains for vacation. Not sure if it is the new pads all around, the new rotors, or the larger rotors, but I was pretty aggressive in my use of them coming down passes, and no sign of chatter from them over heating. Last time I did this with the 80-90k brakes they chattered until cooled off every time Adaptive Cruise would apply the whoa, or I would aggressively due to traffic. I had to both use sport mode, and 4 bars for adaptive cruise to stop it from overheating them frequently.
The rotors, with the shiny coating, look great. the OEM ones had a dull grey coating that still looked okay, stuff doesn't really rust where I live, rotors do but not heavily.
I will likely paint them red next time it isn't in use for a day, which is hard to come by.
They were put on by the dealership before I bought it. They are not great tires but I guess they aren't bad either. I won't be replacing them with the same tires. They are pretty greasy in the heat and not great in standing water. They have 42,000 miles on them and probably be done in another 10k miles.
So no matter that the share the name with the vehicle, it isn't enough to get them!
