Misfire 4 and cats codes
RickVEasley3
3 minutes ago, RickVEasley3 said:
I've replaced coil pack spark plug and still have the code ecm was replaced recently also have chts code replaced sensor still the same codes I'mĀ  at a total lose help is appreciatedĀ
Throwing parts at it is always more costly the following a diagnostic approach.
Ā
You don't provide much info as to the current status.
1) Is it cranking but not starting, or is it running with fault codes?
2) What fault codes have been reported and what device/app are you using to scan for codes.
3) What's the "chts code" ?
Ā
Ā
