agirlonabike Posted June 23, 2024 Report Share Posted June 23, 2024 I'm buying this car from my older sister so I am trying to troubleshoot all the issues before I finalize purchase. 2010 Ford edge limited 2WD My sister had issues with over heating and had the radiator fan replaced. It took like 4 trips to the mechanic to get the fan to turn on when the car was hot enough. The latest fix was a zip tie on the connection. So far so good. No over heating in the past few weeks. I noticed yesterday that the AC does not turn on until a few minutes into a drive. I tried moving around the relays and checking the fuses. I haven't found anything. The fan is not turning on when idling and therefore no AC. Any suggestions on other things to check. I'm not used to working on cars. I work on pedicabs normally so I'm way out of my norm. Talk to me like a small child please. Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 23, 2024 Report Share Posted June 23, 2024 On 6/23/2024 at 5:51 PM, agirlonabike said: I'm buying this car from my older sister so I am trying to troubleshoot all the issues before I finalize purchase. 2010 Ford edge limited 2WD My sister had issues with over heating and had the radiator fan replaced. It took like 4 trips to the mechanic to get the fan to turn on when the car was hot enough. The latest fix was a zip tie on the connection. So far so good. No over heating in the past few weeks. I noticed yesterday that the AC does not turn on until a few minutes into a drive. I tried moving around the relays and checking the fuses. I haven't found anything. The fan is not turning on when idling and therefore no AC. Any suggestions on other things to check. I'm not used to working on cars. I work on pedicabs normally so I'm way out of my norm. Talk to me like a small child please. Expand Welcome. What brand of radiator fan and fan controller is installed? Browse the forum and you'll find that the only reliable replacement for these components is OEM. This is most likely causing the AC issue as well. Quote Link to comment Share on other sites More sharing options...
agirlonabike Posted June 23, 2024 Author Report Share Posted June 23, 2024 On 6/23/2024 at 6:48 PM, 1004ron said: Welcome. What brand of radiator fan and fan controller is installed? Browse the forum and you'll find that the only reliable replacement for these components is OEM. This is most likely causing the AC issue as well. Expand I have already browzed and I've seen this topic a lot. I'm assuming the replacement parts were OEM. I'm wondering if there is anything I could trouble shoot. Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 23, 2024 Report Share Posted June 23, 2024 On 6/23/2024 at 8:59 PM, agirlonabike said: I have already browzed and I've seen this topic a lot. I'm assuming the replacement parts were OEM. I'm wondering if there is anything I could trouble shoot. Expand You will need a suitably qualified auto-elec tech to diagnose, but before that I would confirm if the parts are OEM. Quote Link to comment Share on other sites More sharing options...
agirlonabike Posted June 24, 2024 Author Report Share Posted June 24, 2024 Parts are from advance auto. I'm looking to pick up some OEM parts from a junk yard. I know 2007-2010 is kind of the right years for most things on this car. If I am looking for a 2010 would a fan in this range be correct, or could I enter my search into other years? Quote Link to comment Share on other sites More sharing options...
