Drivers door ajar light problem
For 2011-2013 there was a TSB (18-2013) on it, you can get the part number for the revised latch. There are all sorts of posts and videos here, from cleaning, to replacing, to breaking off the switch so it never does anything (but there are all sorts of side effects to that, like radio not turning off).
Exactly!  I took the door panel off and grounded the green/violet wire.  Stopped the light, but the radio stays on unless you open and shut the passenger door.
I'm thinking there has to be a WY to wire the door switch to trick the computer?!!
